    brake boss help!
    I'm rehabing an old Schwinn Sweetspot frame, and one of the brake bosses is slightly bent. I want to replace it. Not big deal, right? Nope. It uses what look like standard M8 studs which are normally 1.25. However, the thread pitch on these looks to be about 1.33, which leads me to believe the boss isn't metric. Soooooo, does anyone know what these actually are, and as importantly, where I can find new ones?
    The standard M8x1.25 is on the left, the Schwinn one is on the right.
    Yo.
    Reputation: Slow Eddie's Avatar
    Looks wider, unless the pitch is throwing me off. Maybe it's an M10?
    Quote Originally Posted by JonathanGennick View Post
    I am a poser. But forums.poser.com doesn't seem to exist, so I come here instead.
    It's definitely not an M10. If it is wider, it only about 0.1mm wider. I'm not sure what, exactly, it is, but I'm pretty sure it's not metric.
    Did they ever use SAE 5/16"? I just measured the ones in my bin and all are either 8x1.25 or 10x1.25....I know there are some 1.0 pitches out there, 10mm only I believe.
    ...just nosed around the web and couldn't find anything other than those three sizes, but I didn't search on Schwinn either.
