Results 1 to 2 of 2
    Brake Booster on Arch Rivals
    Just bought some Arch Rivals and wondering if A brake Booster would even do that much because of the Arch of the Brake, or has anyone ever put a Brake Booster on the Avid Arch Rivals? Will it even fit? Thinking about the Salsa Carbon Fiber Arc. Thanks.
    Reputation: EBasil's Avatar
    The arch on your Arch Rivals is not a booster. It's only to locate the brake pads, and is hinged at the center (ie where a brake booster concentrates the force). You can run a Salsa, if you really need one, but may have to shim the outside of the Avid bearing to avoid binding the booster against the brake arm.
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. Magura Marta brake drag question
    By dgangi in forum Brake Time
    Last Post: 03-01-2004, 09:42 AM
  3. Avid Arch Rival V Brakes?
    By MenaceAllen in forum General Discussion
    Last Post: 02-24-2004, 06:39 AM
  4. brace for 02 Monster that allows 3.0 tire
    By freeriderB in forum Downhill - Freeride
    Last Post: 02-15-2004, 04:00 PM
  5. Replies: 10
    Last Post: 02-14-2004, 06:04 PM
