Brake bleeding (vacuum brake fluid)
I bled my Avid Elixir brakes yesterday and one of the first steps is to place the brake fluid under a vacuum by pulling on the syringe plunger. I thought about this for a minute and believe I have a better way of doing it. When I raced RC cars I had a shock vacuum chamber such as the one at this link:
Ride*Large Shock Air Remover
It works great and is very easy to use. I just placed the brake fluid from the Avid Brake bleed kit into the chamber with the cap removed and created a vacuum. It's easy and effective and the chamber is relatively cheap.
By Spectre in forum Brake Time
Last Post: 01-11-2011, 06:15 PM
By amt27 in forum Brake Time
Last Post: 08-18-2008, 12:10 PM
By Jasonp in forum Brake Time
Last Post: 03-01-2007, 01:24 PM
By macming in forum Brake Time
Last Post: 07-20-2006, 09:16 AM
By Yoshimura in forum Downhill - Freeride
Last Post: 11-12-2004, 04:14 AM
- You may not post replies
- You may not edit your posts
Forum Rules
