Results 1 to 6 of 6
    Bite Me.
    Reputation: cutthroat's Avatar
    Brake bleed home
    I have a set of the Hayes HFX mags that I think are due for a bleed. They still work fine but haven't had a fluid change in 2 seasons. I reviewed the manual and the whole process just looks like a royal pain, with lots of opportunity for spilled DOT fluid. I'm no slouch with a wrench but I've never done a bleed and fluid change before. My LBS mechanic will do the whole ordeal for $20. Should I just have him do it or try it myself? If you suggest that I try it, any tips or advice on how best to proceed? I have Hayes' bleed kit and a good work stand and all the necessary tools - thanks for any input.
    When I see an adult on a bicycle, I do not despair for the future of the human race. ~H.G. Wells
    Reputation: frank n. beans's Avatar
    hayes bleeding
    IMHO, Hayes are very easy to bleed. Done carefully, you will not spill a drop of fluid. If you do it yourself, I'd recommend using a big syinge instead of the Hayes bottle that comes with their "kit".
    There is always the possibility of error, if you have a good mechanic and do not want to do it yourself for whatever reason, there is nothing wrong with that. $20 is a very fair pice for bleeding a pair of brakes.
    Don't believe everything that you think.
    It's pretty easy
    The very first time I did it I spilled a little fluid. I just did it again a couple of days ago with a syringe like (Mr. Beans suggested) and no spillage. If you have a work stand it's real easy. I used this as a guide...
    http://www.pinkbike.com/modules/news...leview&id=1972
    The container I used for the overflow was an empty Gatorade bottle with a wire coathanger. Wrap the hanger around the mouth of the Gatorade bottle and then wrap the other end around the brake lever. I used some tape to secure the overflow hose to the inside of the gatorade bottle. The whole process took about 15-20mins.
    Sep 2004
    Quote Originally Posted by frank n. beans
    Like Fn'B's said, the Hayes brakes are relativily easy. If you NEVER plan on working on your brakes yourself, you can skip the learning experience. I just find it much more convienient and satisying to work on my ride myself. It may seem a little cumbersome the 1st. time you do the bleed but after that, it is all of a 15 - 20 minute process. I just got done installing a ride kit, verified SPV operation and did a semi-bath change on my Black Platinum forks. Spent a day or so going over the pictorial diagrams, the on-line maintenance manual and rounding up the necessary parts. After a couple of hours, I had it all put back together, it really was a very simple project.
    Another day in paradise!
    Sep 2004
    Also, run to the local animal feed store and pick up a syringe. It works a lot better than the little bottle.
    Bite Me.
    Thanks guys, I think I'll give it a whirl. The syringe idea looks like it will be way easier than the little squeeze bottle. I just need to find a place to pick one up. That article link was really helpful.
  1. Replies: 2
    Last Post: 02-28-2005, 07:06 PM
  2. Big big big brake problem....
    By AdamOn6thStreet in forum Brake Time
    Last Post: 10-15-2004, 01:33 PM
  3. Which brake lever for which brake...?
    By mahgnillig in forum Brake Time
    Last Post: 10-06-2004, 02:18 PM
  4. brake bleed kit
    By fsr in forum Brake Time
    Last Post: 05-10-2004, 11:07 AM
  5. Marta SL bleeding - what am I doing wrong?
    By AnoBlur in forum Brake Time
    Last Post: 03-28-2004, 06:52 PM
