Results 1 to 5 of 5
    Reputation: Mikey_Dawg's Avatar
    Brake Adaptor Help ??
    I just installed a Rock Shox Tora 318 Solo AIr on my Trek 4300. I got through the entire install and was trying to mount the front brake caliper to the new fork and I realized that the caliper does not properly mount to the fork. I believe I have figured out that I need a brake adapter to get the caliper to mount correctly.
    The Tora has a 51mm SI Disc Mount and the front brakes have a 160mm rotor. Does that mean I would a brake mount like this one:
    http://www.wiggle.co.uk/p/cycle/7/Sh...er/5360027299/
    It seems very straight forward.... Just want to be sure I was on the right track so I can getting this thing running ASAP! Thanks.
    Reputation: Ray Lee's Avatar
    If you have Shimano brakes thats the one.... 160mm post to IS
    Quote Originally Posted by Mikey_Dawg
    Or is their another similar item that I need for my setup? Not familiar with any of this yet so I wanted to make sure I was on the right track so I can getting this thing running ASAP! Thanks.
    Any chance the LBS might have that in stock or am I gonna have to order it?
    Meh.
    Reputation: XSL_WiLL's Avatar
    There's a good chance an LBS would have one in stock. I know I've got a few of them.
    Reputation: vk45de's Avatar
    if it looks straightforward, then you're probably on track. of course, we don't know what caliper you have.
