Results 1 to 5 of 5
    Dec 2012
    Brake Adaptor for 1999 Intense M1
    I've run into a dead-end here. Anyone know if there is a mounting adaptor made to install new brakes on to an old M1 frame. I have Hayes Dyno Comp brakes and 6 inch rotors. I would like to use the original 8" rotor up front.
    Anybody have any beta on where to get the appropriate adaptor?Brake Adaptor for 1999 Intense M1-intense-m1-2.jpgBrake Adaptor for 1999 Intense M1-intense-m1-1.jpg
    *Edit* The adaptor for the fork doesn't fit current Hayes brake models (or any manufacturer brake models for that matter!).
    B A N N E D
    On the rear you'll need to use 2 adapters to fit a post mount brake caliper.
    You'll need a a2z AD-PMR adapter to attach to the frame and then you'll need a PM to IS adapter to attach the brake caliper to the a2z adapter.
    http://www.a2zcomponents.com/02products_04adapter_05.html
    This adapter + something like this adapter.
    Front 6" / 160mm IS adapters = Rear 5" / 140mm IS adapters but IS mounts on forks are spaced for a minimum rotor size of 160mm while IS mounts on frames are spaced for a minimum rotor size of 140mm.
    The a2z AD-PMR adapter increases the rotor size by 20 to 25mm
    Possibly with the 2 adapters I linked you'd be able to use a 160mm rotor on the rear, maybe you'd have to use a 180mm rotor, it depends on what size rotor you're using with the 22mm caliper .
    If you currently use a 160mm rotor on the back with the 22mm caliper then I'd say that the minimum rotor size that you could use with the 2 adapters would be 180mm.
    What's the center to center bolt hole measurements for the adapter on the fork ?
    If it's 74mm then you might just need a PM to PM adapter.
    180mm PM to PM adapter
    203mm PM to PM adapter
    Dec 2012
    Thanks Cobba! The center to center is something like 68mm for the fork adaptor. I think I'll need to replace it with the a2z adaptor as well. Is a2z the only company making this adaptor?
    B A N N E D
    Quote Originally Posted by sjstumbo View Post
    Hope used to make one but the 22mm mounts were phased out over 10 years ago so I don't think that you'll find one of those for sale.
    That a2z adapter I previously linked won't won't work on your fork, the fork mounts are 90 degrees different to the frame mount.
    69mm is the old Manitou post mount standard.
    To fit a post mount caliper you'll need to attach a a2z AD-PMF69 adapter to the current 69mm adapter and then add a PM to IS adapter like with the rear mount.
    http://www.a2zcomponents.com/02products_04adapter_03.html
    http://www.woollyhatshop.com/Brake-Spares/Disc-Brake-Adaptors/A2Z-69mm-Manitou-Mount-to-IS-Disc-Brake-Caliper-ADPMF69/prod_40.html
    The a2z AD-PMF69 adapter increases rotor size by 20mm so to use a 203mm / 8" rotor you'd need to use a 180mm / 7" PM to IS adapter too.
    http://www.chainreactioncycles.com/Models.aspx?ModelID=17390
    B A N N E D
    The following adapter looks liker it'd fit on the frame and fork.
    http://www.mountainbikecomponents.co...tense+M1+Mount
    Some more: http://waldmeissler.de/fahrradteile-bremsadapter.html
  1. Replies: 3
    Last Post: 06-18-2013, 05:44 AM
  2. What Brake Adaptor to use???
    By Sevenz in forum Fat bikes
    Last Post: 03-15-2012, 10:02 AM
  3. SS1 rear brake adaptor
    By pizon in forum Intense
    Last Post: 03-01-2012, 10:35 AM
  4. Rockhopper disc brake adaptor
    By robpad in forum Specialized
    Last Post: 02-23-2012, 01:58 AM
  5. bomber 1998 z2 V brake adaptor
    By kaponeoly in forum Shocks and Suspension
    Last Post: 05-10-2011, 05:52 PM
