Results 1 to 8 of 8
    Brake adapters??
    Please help, I have XTR and Magura Luise IS mount disc front brakes and will mount it to post mount fork. Are there any adapters out there to be used on my current 160mm rotor?thanks!
    Reputation: Joules's Avatar
    There is no adapter that will let you put an IS caliper on a PM fork without going up a rotor size.
    Quote Originally Posted by Joules View Post
    Joules, so what adapter do you recommend and what rotor size? I'm aiming for 170mm rotor though, is it possible?
    B A N N E D
    There is one but it doesn't work with all IS mount brakes.
    Product KCNC Disc Brake Adapter Post Fork - IS Caliper
    thanks cobba!
    B A N N E D
    Apart from some IS calipers not being physically able to fit between the post mounts when fitted to this adapter there are some forks that this adapter won't fit onto as well. The placement of the dropout, the size of the fork lowers and the length of the post mounts can also be things that come into play whether this adapter will work or not.
    Adapter that doesn't fit on the fork: Photo 1, Photo 2
    Adapter & Caliper that fits: Photo
    too bad! rockshox won't fit this nice adapters and they are my favorite forks! thanks for the photo cobba!
    The MTB Lab
    Reputation: pastajet's Avatar
    Just get the proper adapter Buy MAGURA #3 from the official MAGURADirect Online Shop and slap on a 180mm rotor. Best to fit in with the standards.
