Results 1 to 12 of 12
    Brake adapters, Are 20mm hubs pretty standard?
    I'm looking for Shimano brake adapters, and it seems the only front one I can find specifies 20mm hubs.
    Is 20mm pretty standard, and what is this a measurement of, so I can double check mine before I order?
    meh....
    Reputation: Monte's Avatar
    Quote Originally Posted by stingray4540
    this is a 20mm front hub. if yours doesn't look like this (the BIG axle ends), you don't have a 20mm front hub.
    what brake (exactly) are you looking for an adapter for, and why? might help.
    this is a 9mm quick release hub. most likely what you have if you don't know what the 20mm in a 20mm hub refers to.
    Thanks, that helps alot. My wheels have quick releases, so they are probably the 9mm then.
    I'm looking for a 203mm adapter for fox f100rl, using shimano XTR brakes. So, I need 51mm to 51mm adapter, but the only one I've found on Jenson is for 20mm hubs.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    since you have IS calipers (51mm), this is the adapter you need if you have a fork with IS tabs
    Oh, thanks, I just found those on Jenson, don't know why I couldn't see those. Too much time staring at a computer screen I guess.
    Old man on a bike
    From what I see here http://techdocs.shimano.com/media/te...9830609096.pdf the M966 is a post mount caliper, the M965 is an IS mount caliper. Are you sure what you have?
    suum quique
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    With 20mm forks, only '06 Marzocchi have a different spacing I think!
    Not your case, so standard 20mm adapter, IS or postmount depending on the fork/brake combo
    Check out my SportTracks plugins for some training aid software.
    Old man on a bike
    Quote Originally Posted by PissedOffCil
    He has a 9mm quick release hub and standard dropouts on the fork...
    suum quique
    Meh.
    Reputation: XSL_WiLL's Avatar
    20mm adapter is for forks such as Marzocchi that use a 20mm thru-axle. They position their tabs 5mm further from the rotor. So the adapter is 5mm thicker. Using this 20mm adapter on a QR fork may result in interference issues. Even Fox and Rockshox 20mm thru-axle forks use a "QR" adapter.
    Vaginatarian
    the Marzocci version has a "z" in the part # for Shimano anyway
    SM-MA-F203S/Z
    for Shimano the part # tells what you have
    SM-MA-Front 203 is size 203 S is caliper type (post or standard) and S fork mount type
    so SM-MA-F203S/S is a 203 adapter for the front with standard mounting on both the fork and caliper
    if the fork is post mount and the caliper is standard then the # would be
    SM-MA-F203s/p
    also , if you have the same mounts front and rear you can use a rear on the front but a rear 180 = a front 203
    Quote Originally Posted by Bikinfoolferlife
    To tell you the truth, I'm not sure. The "M966" I got from the brake levers. I can't find any model numbers other than "Shimano XTR" on the brake calipers.
    Otherwise, I think I figured it out and ordered the adapters, I guess we'll find out if they work when they get here.
    Thanks everyone for the help.
    Old man on a bike
    Well, if you look at the techdoc the different calipers are shown, should be easy enough to match to what you have...good luck!
    suum quique
