Results 1 to 3 of 3
    Oct 2013
    Brake Adapter for old Shimano Disc
    OK, I've done a lot of reading but I cannot find a firm conclusion so I am here looking for help.
    I have a old set of Shimano XT M-755 disc brakes. These are the originals circa 2001 and come with the IS Mount. I have purchased a new frame that comes with a post mount on the rear. The front brake I already have covered with an adapter. The rear mount is more trouble. I am trying to find something definitive if there is a adapter that will convert a IS mount caliper to a post mount on the rear of the frame. The other trick is the new frame is limited to a max 160mm rotor.
    One option is to purchase new brakes but the units I already have are virtually new and I would like to keep them if possible.
    Thanks for any help.
    I ask a similar question Here and I got some great answers too..
    B A N N E D
    Front 160mm post mounts have the same dimensions as rear 160mm post mounts.
    Front: http://www.hayesdiscbrake.com/wp-con...10722-1_RA.pdf
    Rear: http://www.hayesdiscbrake.com/wp-con...10722-9_RA.pdf
    A front 160mm IS caliper is the same as a rear 140mm IS caliper.
    A front 180mm IS caliper is the same as a rear 160mm IS caliper.
    A front 160mm IS caliper/rear 140mm IS caliper should would work with a 160mm adapter on rear 160mm post mounts with a 160mm rotor.
    160mm adapter: Product KCNC Disc Brake Adapter Post Fork - IS Caliper
    Looking at bulky shape of a 160mm front/140mm rear BR-M755, I doubt that it would fit on a 160mm adapter.
    If you have a 180mm front/160mm rear BR-M755 IS caliper it might work on the 160mm adapter as it has more clearance but you'd have to use a 180mm rotor.
    Brake Adapter for old Shimano Disc-74ca1405-3a9e-4fe8-b1be-94fa58ec8f4b_zps8bf10c07.jpg
    A 160mm front/140mm rear BR-M755 IS caliper would probably work on rear 160mm post mounts with a 180mm adapter but a 180mm rotor would need to be used.
  1. Rear disc brake adapter help?
    By Jasontamu in forum Brake Time
    Last Post: 04-05-2013, 01:17 PM
  2. custom disc brake adapter?
    By univega900 in forum Custom Builders & Other Manufacturers
    Last Post: 03-30-2013, 11:33 PM
  3. Brake therapy disc brake adapter
    By ltsltr in forum All Mountain
    Last Post: 07-15-2012, 04:05 PM
  4. Replies: 0
    Last Post: 09-09-2011, 11:59 AM
  5. Hayes disc brake adapter????
    By grantpro in forum Brake Time
    Last Post: 04-05-2011, 09:40 PM
