Results 1 to 12 of 12
Thread: brake adapter
    brake adapter
    what adapter do i need to fit hope is no 3 to a marzocchi forks? help
    ...idios...
    Reputation: SteveUK's Avatar
    Hello, and welcome to MTBR.
    Which Marzocchi fork? PM or IS? Which size rotor do you want to use?
    Diogenes
    adapter
    post mount forks 185mm rotor.
    ...idios...
    I don't think that you can fit the Hope IS calipers to Marzocchi post mounts. I know that there were PM to IS adpators which required a 20mm rotor increase, but they do not work with new Marz' PMs.
    I'm sure somebody will correct me if I'm wrong, but I believe you're going to need a new caliper/brake.
    Diogenes
    Reputation: vk45de's Avatar
    can you elaborate on this steve? clearance issues? alignment? i don't know myself. would like to know more
    there are no clearance issues. there new forks with post mount and i want to use my old is hope s and need an adapter
    no. i meant to ask if there will be a clearance or alignment issue with adaptors available.... like this:
    http://www.pricepoint.com/detail/112...ke-Adapter.htm
    ...idios...
    You may have to accept that you can't use the caliper. Unfortunately, I don't know precisely why the adaptor is no good with new ('07 and later) PM, this is just how they are described. I would suggest that you contact Hope directly and ask for an explanation. Even if it would fit, there's no avoiding the necessity to go up to a 20mm larger rotor.
    Here's a link to the Hope adaptor.
    Diogenes
    not sure really looks like that would work if i got a new rotor. but steve uk reckons there are no adapters for me??
    ...idios...
    "not sure really looks like that would work if i got a new rotor. but steve uk reckons there are no adapters for me??"
    Unless somebody here can clairfy for you, why don't you contact Marzocchi and get their opinion? The fact that both Shimano and Hope specifically state that the adaptor won'y work obviously implies that the Marzocchi post-mounts present some kind of fitment issue.
    Diogenes
    the forks are not new really there 06. so would they be ok?
    i have been woundering would i be able to convert my 160mm and 180mm disc rotors to a 203mm? any help please
