Boss hole fillers/cable guides
Where can I find plastic plugs for the holes left behind in my fork/frame from the brake bosses? It would also be nice to find a cable routing plug for the fork.
Any suggestions?
I'm also looking to find C shaped plastic clips that allow you to clip the hydraulic line onto the frame guides.
neutiquam erro
Plugs here or here.
c-clips
Just some options, I'm certain there're plenty others....
Cheers, Chris
The last part I'm looking for is the small plastic sleeves that go over the hose allowing it to fit into the frame hydraulic cable guides on my Fisher. I have one (lbs had one), but need one more. Does anyone know what this part is called and/or where to find it?
]===> Shaped like this, the hose slips inside of it, allowing for the adaptor to be slid inside of the frame guides.
- You may not post replies
- You may not edit your posts
Forum Rules
