Results 1 to 2 of 2
    Hoser
    Reputation: BC Bomber's Avatar
    Mar 2011
    bleeding question shimano zee
    I have solid bleeds in both my front and rear brake. The thing that's bothering me with the brakes is there is too much free stroke for my liking. So the question is, can i remove my wheel squeeze the lever to push the pistons out slightly and then add more fluid to the lever? Will this work in theory?
    El CicloPath!!!!!!!
    Nov 2012
    Quote Originally Posted by BC Bomber View Post
    Yes, that shoud work. You might not need to add fluid.
    If it doesnt work you only need to reset the pistons and maybe realgn the disc and caliper.
  1. cutting/ bleeding shimano brakes
    By b-kul in forum Brake Time
    Last Post: 06-09-2013, 01:15 PM
  2. Disconnecting Shimano brakes without bleeding
    By shanem in forum Brake Time
    Last Post: 05-12-2013, 07:11 AM
  3. Shimano brake bleeding tool question.
    By Juanmoretime in forum Tooltime
    Last Post: 08-20-2012, 07:50 AM
  4. Shimano Saint...Always needs bleeding
    By stunzeed in forum Brake Time
    Last Post: 04-08-2012, 12:49 PM
  5. M785 bleeding with Shimano Funnel. HELP!
    By ericepark in forum Brake Time
    Last Post: 03-07-2012, 08:33 PM
