Results 1 to 3 of 3
Thread: bleeding ?
    bleeding ?
    i've never had hydraulic discs before and was wondering how often they need to be bled ( once a season with a full tune or just when they feel bad)? also is bleeding my own brakes something that i want to do or should i leave that for a shop. i do almost all of my own tuning/maintanace on the rest of the bike but never have bled brakes how hard is it? let me know what you think.
    rolling in the greens
    Reputation: vermont's Avatar
    once a year
    or if you feel there is air in the line, the air compresses unlike the fluid so if there is air in there the lever will feel squishy. Bleeding is not complicated, buy a bleed kit from your brake manufacturer and it will come with good instructions. Basically you squeeze fluid from the caliper up through line and out the master cylinder on lever until you get no air bubbles.
    Depending on your riding style, type and milage you will need to replace rear pads 2x as often as front...keep checking your pads if they get too low they will gouge your rotors. Not sure of a rule of thumb but i replace em when the material gets less than a 1/16th of an inch.
    Hydro's are the best, enjoy
    good luck with em
    Keith Bontrager: "Strong, light, cheap pick any two."
    "Something strong and light ain't gonna be cheap. -That's what I call bling.
    And cheap and strong ain't gonna be light. -That ain't bling."
    "That said, I never deal with bike shops for the same reasons. I am a ebay and mail order whore and I don't care" -----yetisurly
    A wheelist
    Reputation: Mike T.'s Avatar
    Quote Originally Posted by bikeforlife
    .......hydraulic often they need to be bled? also is bleeding my own brakes something that i want to do or should i leave that for a shop.
    I'm using a set of brakes now that are 2 1/2years old without the need for a bleed. The set before were 1 year and no bleed. Unless there is a fault, there is no "need" to bleed.
    Yes you should learn to do your own and then you know the qualifications of the person doing them. Otherwise it's a crap shoot.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with information and motivation.
  1. Most efficient bleeding?
    By Lucky13 in forum Brake Time
    Last Post: 07-06-2004, 02:43 PM
  2. Replies: 2
    Last Post: 04-16-2004, 05:54 PM
  3. tips/tricks for bleeding xt discs
    By fl jay in forum Brake Time
    Last Post: 04-14-2004, 10:02 AM
  4. Marta SL bleeding - what am I doing wrong?
    By AnoBlur in forum Brake Time
    Last Post: 03-28-2004, 06:52 PM
  5. Need help bleeding my Magura Marta SLs
    Last Post: 02-29-2004, 07:31 PM
