I just got a set of Magura MT2's, which I so far like. My one issue is that they lock up the wheel when the lever is pretty far from the bar. I used to run BB7's where I would tweak them until the wheel locks up when the lever is about 1/4" or less from the bar. Is there any way I can tweak hydraulics to do this? My only idea so far was to bleed them, then right before closing the top bleed port depress the level a bit to push out a bit of fluid (but not let in any air).
