Results 1 to 65 of 65
    New question here. Are bigger discs better?
    I just bought a used Trek 4900 (hardtail) that the previous owner had put Hayes discs on. It came with an extra set of discs because he was switching to 8" from the stock discs. He had the rear mounted up but the front is still stock.
    I'm just wondering if there is any real advantage to the bigger disc or if it (and the required adapter) adds weight.
    Another thing that I wonder about...it seems like the extra leverage of having the caliper held further from the mounting points would increase the likelihood for tweaking a seatstay. Is this something to be concerned about? I ask because I've seen some threads on Treks with cracked or broken seatstays near the disk mounts.
    By the way, I'm migrating the brakes/wheels over to a 2001 Trek 8000 hardtail. The mounting setup is the same between the two bikes.
    The weight is negligible and it is a good idea in my opinion to have larger disks unless you weigh 160 lbs.
    bike tester
    Reputation: syl3's Avatar
    i'm just building a new bike, went over to the lbs and weighed every brake on the shelf.
    for example the hayes nine rear caliper with lever and hose weighs 430g with 160mm rotor and 480g with a 180mm rotor.
    Quote Originally Posted by syl3
    Don't forget the required adapter and bolts. The one on my bike is pretty meaty. I don't mean to nit-pick but if you are concerned with weight...it's something to factor in.
    Double-metric mtb man
    Reputation: Psycho Mike's Avatar
    Ok...couple things. You will pay a minor (60-90g) weight penalty for the adaptors and larger rotors and you'll lose a bit of modulation. On the other hand, you will gain more power and heat resistance/dissipation.
    My bike came stock with Hayes 9's (6" rotor F/R) and some of the local trails are moderately downward pointed stuff (I typically ride a river valley...not super steep or long, but some decent runs that will want to push you to the 45 mph point if you don't work the brakes). I'm a bigger rider (235+gear) and I was able to routinely fade (boil) the front. I upgraded to a 8" rotor on the front and never had the problem again. I noticed the power but also the slight loss of modulation. On a ~30 lb bike, the 3 oz of extra weight for the adaptor and rotor was not noticeable.
    I ended up getting a better brake and going 8" front and 7" rear...overkill for a long travel XC bike, but the brakes have far better modulation for larger rotors than the stock brakes did. Heck, I even went to the local bike park and wasn't able to fade the brakes on a lot more demanding terrain (and I even had the rotors pinging as they were getting nicely heated up).
    As if four times wasn't enough-> Psycho Mike's 2013 Ride to Conquer Cancer Page
    Moran? Let your opinion be free -> F88me
    Quote Originally Posted by gotboostedvr6
    Before dispensing such advice, it's adviseable to sort of know what you're saying, as in putting larger than approved rotors on a fork.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    A larger disk may have negatives too: too much torque for frame and fork (check what the manufacturer says).
    Some difference in weight.
    A larger disk may be more likely to get bent out of true, or develop irritating noices from vibration.
    A larger disc can also present modulation issues.
    Quote Originally Posted by perttime
    That's what I'm mainly concerned with. It's an older frame (2003 Trek 8000 SLR) and I'm not sure if I can even find that information.
    I'm really surprised the rear of that frame can clear a 203. However, I wouldn't recommend it. There are even people on FR rigs that don't run 203's. I'm heavier, on a mid-weight FR rig and I actually do 3000+ foot descents that take close to a couple hours and I don't use, nor need a 203 in the back.
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by Jerk_Chicken
    +1. If you NEED a 203 in the back, you need to reevaluate either your braking technique or your diet. The big rotor makes the rear end lock up very easily, even with xc brakes. This 230lb fella ditched his 185 rotor for a 160 for that reason, haven't had a problem with fading.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    I think the reason the previous owner may have swapped out the disk was because of damage to the original. I looked at the spare smaller disk and it has some wear on it. I laid it on a glass tabletop and it doesn't lie perfectly flat. I suspect it is warped or bent. So, he probably just opted to go big when he got new rotors.
    Maybe I'll just buy a new smaller rotor. I'll ride this one for a while first to see how it goes. I haven't even been able to ride this bike yet. The weather has sucked and I need to get tires.
    Thanks for all the feedback.
    I am a pathetic rider...
    I am going to say you most likely don't need 203mm, I just put a 203 on my bb7's, and if the trail had been dry, they would have been an amazing brake, but with the wet leaves and roots, they were just way to grabby and I was barely able to save the front end on numerous occasions. so if you have great traction, go for the biggest, but if you are riding in any sort of adverse conditions, they are way too much power.
    Save the Earth, Ride a Cyclist
    Coming off my experience with cars- but the general principles should still apply...
    Simply having a bigger disc won't provide any more stopping power unless the brake pad has a larger contact area with the disc. What it WILL do is provide more surface area to absorb and dissipate heat to avoid brake fade during prolonged braking. Since any decent bike brake setup should have no problem locking up the wheels, you should only be concerned with fade and not stopping power.
    Therefore, if you are doing prolonged downhills, a big rotor will help keep the brakes stopping well as you descend. If your downhills are short, all the big rotor will do is add unnecessary weight.
    Since when does larger rotors not produce more stopping power>?
    If the larger rotor has more pad contact, it will produce more stopping power. Whether that is the case will depend on the specifics of the setup. However, stopping power alone is almost never an issue on a bike unless the brakes are fading from a long downhill. If you can lock up the tires, you have already used all the available stopping power. This is simple physics. Short of having a drag chute, you can't get more stopping power than the friction of the tires on the ground provides.
    Stopping power as opposed to the effort needed to squeeze the levers is a separate issue. As long as modulation is o.k., most would prefer less effort needed to produce a given amount of stopping power.
    While I'm not saying your 100% wrong, we can agree to disagree.
    I can speak for bigger rotors and same pads = more braking power. I think it is not because of more friction between pads and rotors, but because of the longer lever arm the disc now has on the hub.
    I think I am being a bit misunderstood...
    I'm not saying that a bigger rotor setup will always not have more stopping power, but to the extent that is does have more stopping power it is due to ancillary factors other than the rotor size.
    More brake pad contact or more leverage due to a longer arm would both be reasons why the larger disc setup could have more stopping power, but it's not directly due to the bigger disc itself. It would be theoretically possible to design a brake setup with a smaller rotor with more instant stopping power by changing leverage characteristics, brake pad shape/design, etc.
    However, what I am saying is that stopping power by itself is not the biggest challenge in a brake setup on a bike. It does not take much force to lock up a bike wheel because there is not that much weight involved. Because of the precision necessary in mountain biking, modulation is far more important. By resisting fade, a bigger rotor could help keep modulation consistent over the course of a big downhill. Fade, if it was bad enough, could also cause enough of a loss in stopping power that it would be no longer possible to create enough clamping force to stop the wheel from turning. This is why downhill bikes need big rotors- they need to be very fade resistant because a long downhill will create a serious amount of heat.
    More braking force can also be nice in that it will take less finger strength to produce the force necessary to lock up the wheels- that is good up to a point- but it could go too far and cause modulation issues and oversensitivity.
    For the OP: The correct choice in braking depends on the use. If you are doing 1000 ft+ vertical descents, you probably are going to generate enough heat to cause brake fade over a long descent. In that case, a big rotor is going to be very useful. However, if your descents are short and quick (say more like 50 vertical feet) there is no way enough heat is going to be generated to cause fade. A bigger rotor will just slow you down by adding weight. This is why downhill bikes have huge rotors and XC bikes have small ones.
    As long as you are generating enough force to lock the tires up, a bigger brake setup won't stop you one bit sooner. That much is not really debatable. What is debatable is the effect of overall stopping power on brake feel, etc., which is often a matter of preference and subject to debate.
    Quote Originally Posted by nealric
    No, you arn't understanding at all.
    The greater braking power from larger discs is ALL about the size. Due to the moment of force being radially further out in space the leverage is multiplied for the given force applied to the disc. Its a pure application of mechanical advantage, in a rotational format. Just think of it as a second-class lever. Increase the lever arm, and you increase the moment of force.
    Also, if you think its easy to lock up a front wheel at speed, then think again. I have Avid Codes on my DH bike, and i regularly struggle to slow on the local trails, and thats with a 203mm front rotor, and a 185mm rear.
    Nightmare on Lyrik st. VI
    Reputation: amrgb's Avatar
    You're missing one thing. The larger the disc the larger its circumference. Therefore, for every wheel revolution the pad drags over a larger area of disc, which is what gives you more stopping power.
    I am following you but in this context your theory is a bit off.
    With all else being the same a larger rotor will produce more stopping power then a smaller rotor with the same input pressure at the handle.
    You are both correct on the bigger rotor. My bad now that I think of it. Part of the problem is I was coming from a car paradigm. Installing a big-brake kit on a car will not change the stopping distance for a one time braking maneuver.
    However, I do stand by that the real issue is not maximising one-off stopping power. If you can't lock up the tires, either your brakes are fading from heat or are not setup correctly. I suspect that is what is happening in takai's situation. I guess it could also be the case that DH tires just provide a ton more traction than the XC tires I am used to. My puny 160mm rotors with Bb7s have no problems locking up my tires at any speed when they are cool. After heating up, that's a different story.
    mbtr member
    cars don't really compare that well to bikes. With cars the center of mass and brake balance is fixed. You add a larger rotor and caliper bracket to a car and the front biased brake system will simply lock the front end up even sooner- braking distance will be worse because the rear brakes are under used. Stick a big brake kit on and it gets even worse, the fluid displaced in the new calipers may more or less what the rest of the system is designed around. It's silly to add a big brake kit to a car without an adjustable brake proportioning valve, and on a street car even then it's stupid because you can't set the balance from light to heavy braking.
    On a bike, none of that is true. Bigger rotor = more power = shorter stopping distance, given infinite traction.
    Mikhail Kalashnikov
    Quote Originally Posted by scottzg
    ...given infinite traction.
    As I understand it, this is the key point. If you can lock the tire up with a small rotor you're not going get any more "stopping power" with a big one on a car or a bike. More brake torque yes, shorter stops no. At least until things get hot anyway. In the end it's the tires that stop the car or bike.
    Reputation: vdubz's Avatar
    You may want to ask this question in a womans forum or your riding buddy who always seems to be behind you. Ohhhh you said "discs" sorry haha
    Reputation: hitek79's Avatar
    Can someone define "modulation" for me?
    Reviewer/Tester
    Reputation: Rainman's Avatar
    It's all about lever pressure.
    The difference between a 160mm and a 185mm on the front end of the bike is that you need less lever pressure to slow the bike down, all things being equal.
    If you brake correctly, ie: use the front brake for 85%+ of your stopping/slowing power then there is no need for a large rear disc, simply because when braking most of your weight is transferred to the front of the bike, which means that it takes only a minute amount of braking to lock the rear wheel. A locked rear wheel isn't doing your overall braking much use at all...not to speak of the loss of control of the rear end.
    Most bikes benefit from a change from 160mm to 180/185mm on the front end, but little benefit from changing to a larger than 160mm on the rear.
    R.
    It is inevitable ...
    What I think he originally meant was stopping power is ultimately determined by traction (of the tire to the road).
    I've never understood this statement. Assuming stock 160s could lock the wheel, and you upgrade to 203s which will also lock the wheel, with traction not changing, how can the big brakes put more load on the fork? If anything, moving the caliper outwards and increasing the torque arm distance, you would have less load at the caliper mounting bolts for the big brakes.
    Vaginatarian
    Quote Originally Posted by amrgb
    doesn't make any difference, the amount of pad touching the rotor is the same, if the rotor was straight and the brake pads gripped it and stopped in say 4" would they stop any faster because the distance was longer? no they would still stop in 4"
    as mentioned above heat dissipation is what you gain from bigger rotors
    Vaginatarian
    Quote Originally Posted by b4 stealth
    not so fast
    wouldnt the bigger rotor also have more torque against the pads
    Vaginatarian
    Quote Originally Posted by takai
    No, you ain't understanding at all.
    you're leaving out one thing, the larger rotor is also directing higher torque to the pad because its spinning faster than a smaller rotor
    just as a bigger gear on your cassette moves you slower it has gobs of low end torque
    as far as your DH analogy, I bet you can lock up the front wheel before everything heats up
    but after, its another story. while not DH, my brakes stop fine until sustained downhill braking, with a bigger rotor they don't fade
    I think were both right here its just a matter of which forces are more powerful, the longer leverage or the higher torque, or the cooler big rotor vs. the hotter small rotor
    the truth is probably somewhere in the middle
    Didn't read the all post's but a larger rotor will offer more raw stopping power but the modulation will change slightly. A 160mm rotor and a 203mm rotor share the same pads and contact area but the larger rotor is further from the rotor, torque... blah blah blah. The added power changes the modulation, I diddn't say reduces because the master cyl. & caliper are the same - the additional power is more to harness @ your finger tips.
    Quote Originally Posted by dan0
    not so fast
    A larger rotor has less torque against the pads. Or another way of looking at it is the pads have more torque on the rotor. Think of the rotor as a lever. The larger disk is a longer lever.
    I think we should go back
    Nov 2008
    Why do they make larger front rotors than backs? I have rim brakes and the wheels never get warmer than about 100 degrees F
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    http://www.minimania.com/web/SCatagory/BRAKES/DisplayType/Calver's%20Corner/DisplayID/933/ArticleV.cfm
    Vaginatarian
    Quote Originally Posted by drain bamage
    as mentioned earlier, when you hit your brakes your weight shifts to the front, so thats where most of your stopping power is. larger rotors ( like your wheel) have a bigger area to dissipate heat so they stay cooler ( plus on a rim you have a couple of inches of air between the 2 brake shoes)
    Neilric, you shouldn't have conceided so early. the complete story of fade has yet to be told. you can get pad fade and fluid fade which will both decrease your stoping power. if your still heating your brakes up too much then you have no choice but to switch to a brake with higher thermal capacity. a larger caliper is what is going to decrease fading, not increasing brake torque. switching to a larger rotor is not really addressing your fading issues, if it is solved just by adding brake torque you didn't need a very substantial increase in thermal capacity to solve your fading in the first place (fluid and pads would have worked). switching to a pad and fluid that can take more heat would have been a better route and you would have maintained your modulation.
    to even talk about brakes with absolute tire grip is completely impractical (and a red herring). why not talk about the suspension advantage of hover bikes or other such impossible things? they have no practical application in the real world.
    The proper way to address fade is:
    1. if your levers still have pressure you have exceeded your brake pads heat range.
    2. if your levers get too squishy then your boiling the fluid and should switch to a higher temp fluid (ate super blue is pretty bombproof).
    3. get a larger brake caliper with a higher heat capacity (larger piston or multi piston design)
    4. if your still fading, you have no choice but to go for a larger rotor or a 2 pc floating rotor
    hydraulic brakes are hydraulic brakes are hydraulic brakes. if they are for a bike, motorcycle or car. You can't ignore the library of knowledge about how they work. If you don't want to believe this, that's fine by me. you can go plant a magic bike tree in your backyard with the magic bike tree jelly beans some old hippie gave you, water them every day and hope for something to grow. There is no mystery behind how a brake system works. it is not different for mountain bikes.
    Quote Originally Posted by BigClunke
    If this were true, car manufacturers would use exotic pad materials on 10" disks for their high end cars. In reality, the opposite is true, there's a noticable trend toward bigger disks on high performance cars.
    It's assumed a larger diameter disk is going to have more mass. Going from a solid 160mm rotor to something like the aligator 203mm rotor will only increase leverage but won't do much for fade resistance since the mass is about the same.
    What you left out is the larger cooler disk carries heat out of the pad. The caliper is not supposed to act as a heat sink even though it does to a certain extent. The multiple piston design is not meant to transfer heat better. Think about where that heat goes once it heats the pistons.....the fluid.
    mbtr member
    Ummm... if you're using your calipers as heat sinks... stop riding your brakes down fire roads. Rotors are what manage the heat in the brake system, and larger rotors increase the size of the heat sink and the surface area to bleed off heat. Larger calipers are a byproduct of making a stiffer caliper (for power) or a multi-piston caliper (for modulation). Large calipers are NOT intended as heat sinks- they're designed to soak up as little heat as possible.
    Oh, and floating rotors are designed to resist warping, they're marginally worse heat sinks.
    Mikhail Kalashnikov
    Come on, you guys....
    The basic principals is known as the "moment arm"---> radius x force = constant
    When rotor size is 160mm and you apply 2N to brake lever, then you have .32NM.
    If you upgrade to 203mm, you only need to apply (.16M/.203M) x2N = 1.57N to achieve the same braking power as in 160mm. That's why a bigger rotor always have better leverage and produce bigger braking power. Heat dissipation for a bigger rotor while it may be better because of larger heat exchanging surface, it is really insignificant (for XC you never reach 60 mph, do you?). Leverage is the key.
    ...idios...
    Reputation: SteveUK's Avatar
    "If this were true, car manufacturers would use exotic pad materials on 10" disks for their high end cars. In reality, the opposite is true, there's a noticable trend toward bigger disks on high performance cars."
    Formula 1 cars use (relatively) small brakes made from carbon fiber, although the fact that they almost don't work at all at low temperature obviously precludes them from pretty much any other application, especially on a mountain bike.
    Diogenes
    Nov 2008
    wow this is a little confusing?? lol
    Lol, get a step stool and put it in a doorway. Then stand on it and jump up until you slam your head on the doorway.
    Quote Originally Posted by SteveUK
    They're not that small when you consider the weight of the car which is about 1/3 of your average family car.
    ...idios...
    "They're not that small when you consider the weight of the car which is about 1/3 of your average family car."
    If we're making comparisons, it could also be considered that it would be something of a rarity for the average family car to be braking from 185mph. An F1 brake disc will be no larger than 305mm (12in). If diameter were always relative only to weight, how small do you suppose an MTB rotor would need to be?
    Diogenes
    Quote Originally Posted by BuickGN
    Exotic car manufactures do use the smallest disc available on their REALLY high end race cars (to reduce weight and decrease wheel rotating mass (size)).
    Big disc's are bling, drilled rotors are bling, to some extent multi piston calipers are bling (if done for the wrong reasons). it is more important to look at what they do with their race cars than doing than street driven general consumer market cars (more about marketing than performance).
    you are correct about larger discs having more mass and area to distribute heat, I didn't mean to come across as denying that, but you have to run through the first 4 steps I listed before you should really go to a larger size. you also might want to increase cooling before as well (in cars, venting and aero bits are a bit more practical than dh mountain biking, but probably should be explored to a greater extent).
    the rotors do carry heat out of the pad, but you only need to remove so much (it is just one part of the equation). you can run them hotter with a bigger caliper (more fluid to resist fade, spread heat), better fluid, and a higher temp pad.
    also, simply adding more pistons and not increasing the volume of fluid in the caliper would not help fade, agreed.
    However, most multi-piston designs are to increase the volume of fluid available in the caliper and still keep the pad contact consistent (under heavy braking with poor venting design, the fluid can heat at different rates and cause poor pad contact, brake feel, and result in irregular pad wear. that is more relevant to automotive applications though, we don't generate nearly as much heat on bikes).
    All I'd really like to get across is that most people are not troubleshooting brake fade correctly, they are loosing performance without reason and buying into the bling/hype. Some people are going to need to increase rotor size as a last resort, but we shouldn't reward lazy engineering with our hard earned dollars.
    One thing that I should address because I am sure someone else is going to bring it up, higher temp brake pads are squeaky, dusty, require a higher initial heat range (don't stop well when cold, you need to heat them up) and wear quicker.
    So, there is a balance that needs to be achieved. just as there are drawbacks to going with too large of a caliper (spongy feel), and a higher temp fluid (needs to be changed more regularly due to water absorption which decrease feel). We all have different needs and tolerances. If you would rather sacrifice modulation and can't compromise on any of those other areas, OK, go for a larger caliper without trying anything else. I'll be waiting for you at the bottom
    Quote Originally Posted by Harman
    what does this have to do with brake fade?
    the topic of brake torque without regards to tire grip is completely irrelevant (red herring argument).
    you do not need to upgrade anything if you do not experience some sort of brake fade.
    no one needs the ability to lock their wheels more easily (that is bad). we just need to be able to stop in the conditions we ride in (if that is down fire roads with the brakes on, so be it). I think you'll see manufactures such as formula making use of larger calipers in high heat situations. you want the smallest rotor you can run, this bigger brake stuff is mostly nonsense marketing.
    The rotor is still the primary heat sink no matter what size rotor you run. I live in Michigan and have no problems with brake fade in this state (but If I did ride fire roads with my brakes on the whole time, a brake could still be engineered for that). However, I do HPDE and TT events in my wrx and have learned a great deal about brake fade first hand and through lots of reading/troubleshooting.
    to make a caliper stiffer you only need to add more metal not increase the volume (which manuf. do for DH brakes), multi piston designs are to maintain an even pad contact when increasing the fluid volume. the caliper is not the primary heatsink (when did I ever claim that?), but they have to function in a high heat environment, more fluid volume helps, as does fluid that resists boiling. each piece is part of the equation.
    Maybe what I have been unclear about is, I am proposing that a higher heat environment is just fine as long as you have the right equiptment (pads, fluid, large enough caliper), you don't have to gain weight and loose modulation in most cases. the MTBR.com knowledge base is troubleshooting brake fade backwards.
    on the 2pc, cars use them because the heat range is so extreme you start to fry wheel bearings. they do act as a heat buffer (worse heat sink). thanks for correcting that.
    maker of trail
    Reputation: essenmeinstuff's Avatar
    This is funny.
    1) "Brake power" is the thermal dissipating capacity of the brake, ie how much energy per second the brake can get rid of with out over heating, this is its primary purpose. This is dependent on many factors, air flow, disk area, disk ventilation, disk material, fade limit of the pads etc.
    2) The diameter of the disk determines two things, the physical cooling area which translates to long term thermal capacity, and the moment of torque for a given pad pressure. From a wheel axle torque perspective (the bit that slows you down ultimately) larger rotor needs less force for the same wheel torque, meaning the same caliper can give you more torque, or you can use a smaller caliper or less force.
    If you know a little physics, you know that power = force X speed, or its rotational equivalent, torque X rpm.
    So now, if you put a the same caliper with the same oil pressure on 100mm rotor or a 200mm rotor, you will see two things.
    1) The torque seen by the wheel doubles from 100mm to 200mm
    2) Assuming the wheel is still turning the same speed (rpm) the brake is now dissipating twice the power.
    Since most brake pads are not very good conductors of heat, the disks deal with the bulk of the thermal dissipation, which is why you see vented rotors in cars (if anyone tells you they don't work, they don't know what they are talking about.)
    Since thermal dissipation in air is roughly proportional to surface area, doubling the dia of the disk roughly doubles the area (i do say "roughly").
    You can increase cooling for a given disk by ducting more air onto the disk, or through it in the case of ventilated disks. You can also increase the thermal mass of the disk to "spread" the heat out in time, this is more applicable where the brake is not on often but when it is its a lot of power.
    Fade happens for several reasons the two most important:
    1) brake fluid boiling or absorbed water, this causes fade because a gas can compress, where as a hydraulic fluid cannot, this can also lead to vapor lock in sealed systems (ie the brakes remain "on") prevented by cooling the caliper, or the fluid, or using higher temp fluid.
    2) pad material over heating and either glazing or gassing both result in a drastic reduction of friction. This can only be over come with keeping the disks cooler or higher temp pad materials.
    In short, a bigger disk on a mtb gives yo more stopping power, more thermal dissipation meaning more power for longer and reduction in fade, it requires less work input (pad pressure) for the same stopping force (assuming the same caliper is used), it can actually put less force on the frame for the SAME stopping force if it is a 8" specific mount, however since most frames have 6" mounts and you extend the mounting with an adapter this is canceled out, same with the fork, meaning given the same stopping force (at the wheel) the same force is put on the frame independent of disk size.
    The down sides are:
    1) less modulation
    2) If traction is good (eg tarmac) then the same caliper can exert exactly the same force on the disk, due to the longer disk lever means more braking force and since this force is essentially "backwards levered" onto the frame or the fork by the adapter it results in proportionally MORE force on the frame or fork, which can lead to failure.
    Reputation: ALLMOUNTAIN18's Avatar
    Nov 2008
    A lot of good information here...
    mbtr member
    Oh, good! You're not a moron!
    ...but i still disagree- it's a bike, not a car. Brakes are only gonna work properly at a given temperature range, and unlike in auto racing, mtn bikes go long enough without braking to let the pads totally cool, and then they feel like crap when you need them again. Inconsistent brake performance is really irritating, and the high temperature pads are kinda digital anyway, you're sacrificing modulation by having to use them at any temperature.
    Additionally, a larger rotor doesn't decrease modulation, it just increases power while modulation stays the same. The rider can control the weight distribution and front/rear brake bias, so a larger rotor actually feels more balanced than equal sized ones- you get your weight back and grab the levers equally hard and both wheels run out of traction at the same time.
    You can set up your brakes however you like, but i've tried almost anything, and i hated dh pads and 160 rotors and love 203/160 with organic pads.
    Mikhail Kalashnikov
    Nov 2008
    so let me get this straight, bigger discs=better braking power, and smaller discs=lighter? is that the best features or am i in way over my head??
    mbtr member
    Quote Originally Posted by 2Dmurdoc
    yes. Smaller disks also can conceal poor modulation because they don't produce much power anyway.
    Mikhail Kalashnikov
    Well, since a bigger rotor requires less pressure to clamp down on the caliper (to produce the same braking power as the small one), less heat is produce per unit area. Therefore, it is less likely to fade. In addition, the slightly bigger rotor provides more surface for heat dissipation, which help in cooling it down as well.
    While a bigger brake pad does help in stopping power, it also generates a lot of heat per unit area as the braking surface in contact with the rotor has been increased. Therefore, it is actually more prone to brake fade. But you'll stop faster (assuming no tires skidding), just can't do it all the time and you'll have less modulation.
    It's not a simple matter of "being able to stop", or having enough power/torque to overcome tire traction.
    As was mentioned, a larger disc needs less lever pressure for the same stopping force, and that is a big benefit on long downhills, or repeated lift access/shuttle runs, reduced hand/forearm fatigue improves control.
    maker of trail
    Close, but wrong.
    The heat generating "area" is the brake pad contact with the disk. The pressure is less with a bigger disk (for the same braking force) thus less force is being exerted by the pad on the disk, but since the disk is moving through the caliper at a higher velocity (bigger circumference) the power and thus the heat generated are the same (note heat and temperature are NOT the same). It is however "spread" over a larger disk area and thus easier to dissipate to the air.
    Regarding the larger pad, assuming the same braking force, there is actually LESS heat per unit area with a bigger pad, since the same work is spread out over a larger area, if the braking power is the same, then the heat energy per sec is the same.
    Since for most materials the friction force is a factor of contact force (note NOT pressure) and the material, area does not come into it. This means, same material, same pad force, the pad area has no effect on braking force, just heat distribution.
    There are lots of intertwined factors here, you have to be very careful how you look at, other wise it might seem right, but is very wrong.
    This is true.
    I just changed 6 in in front to a 7 inch and 6 inch still on back.
    The 6 inch had something on the rotor (oil) so I could barely use it I about endoed 3 times b/c the front brake seemed to grab so dang hard.
    After fixing the rear as well though I found it was mostly that I was unable to have such different results from the same pressure on different levers. Now that I am used to it though I love it. I can use my pinky on the front brake lever if I wanted, two fingers are better though.
    I agree that using a pad with too high of a minimum operating temperature is not good, but mtb pad manufactures could be doing a better job trying to use more advanced materials, advertise heat range, etc. I feel they have gotten to be "lazy" because there is little market demand (because everyone is more concerned with bigger being better). there are dozens of good automotive brake pad manufactures, all with different compounds and heat ranges to meet your specific needs. I think that "digital" (on/off?) feeling from high temp pads is more of a result of a poor balance in the friction material and not necessarily inherent to high temp pads (many auto pads have too much "bite" for my liking, some people love that).
    I suppose your right about modulation. if you move the caliper out it does not affect the amount of pressure the caliper is exerting on the disc. however, in practical application making it easier to lock up the wheel with less pressure results in a reduced ability to finitely apply different partial braking power. what people often refer to as modulation is really not static like a lab experiment with a constant pressure because we are bouncing around the trails, have a adrenaline rush going, and different environmental factors that all go into how a brake "feels" (which really is different than modulation).
    the weight distribution and brake bias is also another important factor as you mention, but that is not really unique to mountain bikes, but can be controlled to a greater degree than a car or motorcycle. a late braker is going to put more stress on the front in short burst of more extreme heat (friction). different techniques require different brake set ups.
    the most important thing to come away with from all of this discussion is there are many ways to tailor your brakes to meet your needs and style. bigger is not always better, but it is not wrong to go bigger if you've tried to address fade in the other ways first.
    Very true.
    Quote Originally Posted by essenmeinstuff
    Close, but wrong.
    This is true. Still heat is less per unit area cause it is spread out.
    That is true (KUDOS) provided the braking force is the same. However, in my mind, I made assumption (which I should have made clear) that the original force that applied to the 160mm rotor is also applied to this brake with bigger pad (and resulted in faster stop).
    Wow...this thread is still going.
    I wonder why there are so many comparisons made here to car brakes rather than motorcycle brakes.
    I am also an avid street motorcyclist and my bike (99 Honda CBR600F4) has two large front cross-drilled rotors with 4 piston calipers on each disk. I know motorcycle racers are VERY concerned with braking and also with weight but NOBODY runs a single disk or a small disk to save weight. They all run big disks and big pads (usually 6 piston calipers). Braking loads are tremendous coming into corners and brake fluid boil and fade is a major concern.
    In fact, it may be worth mentioning that there are some excellent racing brake fluids out there for motorcycles that will not boil under almost any circumstances and might be perfect for bicycle brakes.
    I'm still running the big disk and it seems to work okay but it chatters really bad. I would remove it and put the small disk on but one of the bolts holding the rotor to the wheel was over-tightened by the previous owner (like everything on this bike) so I'm stuck with it for now.
    Thanks for all the info, everyone.
    mbtr member
    Quote Originally Posted by Tweezak
    You can use a cutting wheel on a dremel to make a slot to put a screwdriver in. I've had to do that on brake rotors before, it works well since the bolt heads are mushroomed.
    Agreed, clunke, it would be nice if pad options were clearly laid out and described in the literature, but who would want to be the first to potentially drive customers away?
    Bigger IS better.
    Mikhail Kalashnikov
    I've used cars because that is what I know. also, the brake systems just get larger as you stop more mass. the basic mechanics and principals remain the same no matter what application. also, you'd know better than me about motorcycles, but I would imagine smaller lighter bikes use smaller discs because they don't need to go bigger. you hit a point where the brake is as big as it needs to be without getting fade (same with race cars, mountain bikes, semi trucks, etc)
    There are trade offs no matter what way you choose to combat fade, you need to find a balance.
    If bigger was always better we'd constantly be going larger 245's, 304's etc it would never end. obviously, there is an appropriate balance for all situations and a lot does come down to preference.
    also, this thread has taught me that If I want to make a quick buck I should start to make 220 discs and adapters. when that starts killing mounts, I should start to make forks and frames or bolt-on reinforcements. people actually would prefer to solve their braking problems this way so let the free market speak
