Results 1 to 6 of 6
    The Top Cap Guy
    Reputation: Fast Freddy's Avatar
    Better idea for Shimano XTR Clip on bolt that holds pads in place?
    I have lost one of the clips that go on the pad replacement bolt on my XTR Disc brakes. It was just a slip on clip. Is there anyone who knows the size needed if I wanted to change it out to a TrueArc ring? The little c-clips style ring? That way I wouldn't worry about it falling off on the trail and then the bolt loosening up and my pads falling out? I tried a 5/32 ring and it was too big (smallest they had at Lowes Hardware).
    Fred
    "If I'm leading, I'm bleeding."
    Chrome Toaster
    Reputation: Hecubus's Avatar
    I'm not sure what size but I've lost that stupid little clip on every single disc brake I've used that uses them including my XTR's. Just keeping the bolt tight enough does the trick if that makes you feel any better. Someone once suggested using something like a small safety pin or something along those lines which supposedly stayed on better but I can't remember now.
    I already rode that
    Reputation: SuperNewb's Avatar
    I lost mine first ride. Just like Hecubus said just tighten it and it wont come out.
    Live 2 Ride
    Reputation: Kona0197's Avatar
    I have a set of Shimano Deore mech discs. The bolt that holds the pads in place on top stripped out so I used cotter pins. Sliped them in and bent them down. I have been riding them for a few months like this with no problems. The cotter pins hold the pads and springs just fine.
    My Bike: '15 Trek FX 7.2
    My Blog: http://http://kona0197.wordpress.com/
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    Quote Originally Posted by Fast Freddy
    Fred
    I picked up an e-clip from Home Depot. I bought a size too big, but with some careful attention from my pliers it worked just fine. Like the rest said though, usually you won't have a problem if you just keep the bolt tight but I didn't want to have it rattle out on a DH run or something like that.
    Authority is dead!
    Reputation: Lucky13's Avatar
    Steel or Al wire, come on guys!
    For the love of Oi
    Rent a house at Attitash
  1. XTR Dual-Control, stripped lever adjustment bolt.
    By Astroboy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-26-2005, 09:16 AM
  2. Best pads for XTR disk calipers?
    By fallzboater in forum Brake Time
    Last Post: 11-30-2004, 05:38 PM
  3. Lost bolt that holds disc brake pads!
    By OffRoadRoadie in forum Brake Time
    Last Post: 07-29-2004, 12:48 PM
  4. Tuning up XTR disc brakes - pads etc. ??
    By rpbt in forum Brake Time
    Last Post: 06-05-2004, 09:26 AM
