Results 1 to 2 of 2
Thread: Best Bleed Kit?
    Mar 2006
    Best Bleed Kit?
    I need to bleed my Hayes brakes and I have been reading about how crappy most of the bleed kits are - can anyone suggest a kit that will work well?
    "If at first it doesn't bleed, try try again."
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Bleed tools are up to the individual, many like the syringe some like the squeeze bottle, advantage of the squeeze bottle is a smooth steady flow of fluid, syringes can inject too quickly if not used properly. You will need the bleed fitting if you are going to build your own.
    http://www.bti-usa.com/public/manufa.../HY/BR/?page=2
    Your local pet store that sells fish should have air pump hose which is DOT proof and comes in 2 sizes. I use the larger diameter as the mail hose and the smaller diameter for a snug fit on the caliper nipple, Hayes suggest using a compression fitting over the hose to nipple. Any super market will have syringes in the cook ware section for meat injection. Next you will need a catch tank, I use a old DOT plastic bottle and safety wired a leash to wrap around the bar for the master cylinder bleed hose to go into.
    http://www.pricepoint.com/detail/157...eeding-Kit.htm
    Formotion Products
    http://www.formot
