Results 1 to 8 of 8
Thread: bent lever
    Reputation: tylerdurden119's Avatar
    bent lever
    So I nailed a tree the other day, and bent the end of my lever. Is it possible to bend it back by heating it up? Or is it garb now?
    Dirt Deviant
    Reputation: savagemann's Avatar
    What kind of brake? and what is the lever made out of?
    If it is alluminum and there are stress fractures, you may want to replace it.
    Most levers are either designed to break or bend in the event of a crash. the ones that bend can usually be bent back.
    Look, whatever happens, don't fight the mountain.
    not sure
    It's a juicy leve, looks like its either alum, or some kinda alloy. Do you think its necessary to heat it up to make it more plyable? There are no stress factures on it. If it breaks it breaks, I've already written it off in my head. However if it works saweet.
    Reputation: skywaybuzz's Avatar
    Just bent mine back last week. Take the lever off the brake lever, put in vise and bend back slowly
    Reputation: swift's Avatar
    I bent some Juicy levers in the past too and I just pulled the lever off, put a cheater pipe on the end and bent it back to it's psuedo-normal spot. YMMV.
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    tylerdurden119 - pm me your addy...i always swap my levers out for db (rip) or straitline so i have a few stock levers laying around...i'll send u one
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    Dirt Deviant
    Thats one helluva a bend!!!!!
    I'd give it a go, but if Pipes will send you one that would be super cool!
    Either way, take the lever off before you try to bend it back. No need to heat it up.
    Calm Like a Bomb
    ^^hey, bikers helping bikers out...that's the way it should be....
    tylerdurden119 - even if u do bend that lever back i doubt it's going to feel all that great...let me know if u want me to ship out a lever to u...no charge
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
