Results 1 to 16 of 16
    Reputation: deesta's Avatar
    'Bedding in' brake pads
    Hi all,
    I've just received my Alligator rotor, EBC Gold pads and Hope 20mm adaptor and was wondering - What is the best way to bed the pads in properly?
    I'm off to Afan at the weekend and want to make sure they are working properly.
    Cheers, Steve
    Use them.
    Fall guy
    Reputation: phlakvest's Avatar
    Quote Originally Posted by gmcttr
    Use them.
    On flat ground to begin with.
    Old man on a bike
    I like a nice long and not too steep hill that permits me to gain some momentum then fully but gradually apply the brake and repeat that several times, am generally well bedded in by the bottom...of course it helps that's easily done where I live.
    suum quique
    Reputation: vk45de's Avatar
    I like to downshift, grab the brake lever, and pedal away until it hurts. Of course this works better for rear pads then front but hey you can swap em.
    ...idios...
    Reputation: SteveUK's Avatar
    "Of course this works better for rear pads then front but hey you can swap em."
    Swap rotors and pads?
    Diogenes
    Thanks Guys,
    I reckon a little bit of 'flat' work then a gentle 'roll' down the 'worcestershire beacon, with them on should do the trick then
    Quote Originally Posted by SteveUK
    it's a preference... if your rotors are same sized. of course you can do it in situ you just get more tire wear
    Old man on a bike
    Quote Originally Posted by vk45de
    ? The bedding in is a mating of the pad to the rotor, so if you switch pads you'll continue just to work on the rear rotor instead of the more important front one...
    suum quique
    ...idios...
    "it's a preference... if your rotors are same sized. of course you can do it in situ you just get more tire wear"
    You're bedding the pads into the rotor (and vice versa), so swapping pads isn't going to work.
    edit. Writing at the same time as Bikinfool', so 'scuse the repeated info...
    Diogenes
    Bicyclochondriac.
    Quote Originally Posted by deesta
    Hi all,
    Cheers, Steve
    I just ride them, keeping in mind that it will take a few hills before they work very well.
    nnn
    nnn is offline
    Reputation: nnn's Avatar
    Feb 2005
    Yep, I also find it best to just ride the pads, maybe splatter a bit of mud on the rotor to help the grinding process a bit.
    Screaming down a hill and grabbing the brakes can easily glaze the pads.
    "Life begins at 140" Richard Burns
    http://www.nikolay-k.com
    Quote Originally Posted by Bikinfoolferlife
    Uh of course I know the same sized rotor isn't the same rotor. Perhaps I should clarify, it's a matter of preference for those who run same sized rotors to swap rotors + pads. People who don't have to just do it where it is.
    ...idios...
    "Perhaps I should clarify, it's a matter of preference for those who run same sized rotors to swap rotors + pads.
    So you'd suggest removing the rotor and pads from the front and fitting them to the rear to bed them in?
    Diogenes
    it's just something you can do. esp if you just bought the brakes
    Bicyclochondriac.
    Sounds like a lot of work. Why not just pedal with the front brake on?
