Results 1 to 7 of 7
    Butts Up Fast!
    Reputation: Stonebreaker's Avatar
    BB7's with XT or XTR levers
    Do BB'7 work well with XT or XTR levers. I have a set of dual control XT levers and a set of XTR levers both used with V brakes. Would either of these work well with the Avid BB7 calipers?
    Old man on a bike
    I used the older XT integrated brifters (ST-M750's, with trigger shifters) for years, but there's only three settings for the leverage control (via adjustment blocks) whereas my XTR M950 levers have more adjustment of leverage with a screw type adjuster. I have no complaints with either.
    I believe the later dual control vbrake levers only have one adjustment block. None of the Shimanos are as easy to adjust for leverage as Avid's speed dial knob on the outside of the lever, ready for instant adjustments. As to how much you need/want to adjust your leverage with the BB7s is personal choice...
    suum quique
    uh, or something!
    Reputation: mello211's Avatar
    Dec 2005
    i use my xtr m950's
    that would typically be used with v brakes with the bb's and they work like ten men
    Life is a drink and you get drunk.... when you're young.....
    Reputation: peternguyen's Avatar
    Are there any ways of having the leverage point on the XTR lever fixed in position, instead of having it increase/decrease throughout the lever stroke?
    Old man on a bike
    Quote Originally Posted by peternguyen
    I'm not sure what you mean by that...once you choose a pitch adjusting screw position it changes for you? Or do you mean the "servo wave" action?
    suum quique
    Quote Originally Posted by Bikinfoolferlife
    Yeah that's it. You know how on the servo wave the cable end starts at one point, and moves inwards as you pull the lever? Is there any way to keep it in one place the whole time instead of it moving? I was thinking, maybe insert something in there from stopping it from return back to the top?
    Old man on a bike
    I suppose you could try to put the pitch fixing block back in...
    suum quique
