Results 1 to 50 of 50
    bt
    bt is offline
    Nov 2007
    BB7's. Are they as good as some Hydro Brakes?
    I'm reading a lot of hype about the mechanical BB7's and it has me interested in trying a set.
    Are they really comparable to say Juicy ultimate's?
    Old man on a bike
    Price wise they're not comparable at all. BB7s work great, though.
    suum quique
    Daniel the Dog
    Not to me
    Quote Originally Posted by bt
    I had BB7's and went to LX disc brakes. I don't think the BB7's are as nearly as good as LX disc brakes; however, some folks love BB7's. You may be one of those people.
    Jaybo
    Jul 2003
    No they are not comparable...
    to J Ultimates. They're not comparable in feel or performance. But they are better than almost any low end hydro, and comparable to many mid level hydraulic brakes. With that said they are not hydros, they feel different because they are mechanical and have a slightly mechanical feel to them. If properly set up they feel quite a bit like a high end well set up set of V-brakes, but stronger and with more modulation, and much better adverse condition performance. It's very difficult to compare hydraulic brakes to mechaincal brakes. They are very different systems that use very different methods of "advantage" in transfer of lever movement to the pads. The mechanical brake uses leverage, i.e. a lever pulls a cable that pulls another lever. The hydraulic brake uses, obviously, hydraulics. A column of flud is pushed by a piston atached to the lever which in turn pushes another piston to move the pad. The hydraulic system has a better adavantage, that column of fluid becomes a solid when contained by the brake line and is just like pushing a metal rod against the inside of the caliper piston. Physics 101, you can compress a gas but you can't compress a liquid. That's why hydraulic lock outs on forks work so well.
    The bottom line is, there are very few hydraulic brakes at the price of a BB7 that will perform as well. But there are quite a few that perform better as long as you are willing to spend the money. A set of Juicy 5s will perform about the same or a little better than BB7s, but you'll pay aobut twice the price for them. But as far as feel at the lever, etc., they'll be very different. The best thing to do is ride them back to back if you can. Then you'll get an idea of the differences. Performance isn't all about stopping power or the ability to toss the rider over the bars, or lock up the wheels. Yes it's part of it, but lever feel, adjustability, and the way the available powere is applied has the most to do with it. My personal preference is for the BB7. I like the adjustability and the feel of the mechanical disc system.
    I know this isn't helping much, but it really isn't quite comparing apples to apples when comparing mech discs with hydros. BB7s will feel very much like a good set of V-brakes at the lever, but, if properly set up, will have better power and better modulation than any v ever did. But they're not hydros. They may perform as well as many, but they just don't do it the same way, if you get my meaning. I'd say if you at all can, ride both the BB7 and a hydro that you like. Then make your choice. You'll know the differences first hand. And you won't have to rely on the advice of biased rambling old men like me!
    Good Dirt
    knock-knock...
    Reputation: skottt160's Avatar
    i like em
    Good advice from Squash. My bb7s were easy to install following Avid's directions. It only took a few rides to get them adjusted to my preference. Like Squash said, at the lever the feel like V-brakes. I have the same stopping power as my v's, but with less force, more modulation, and much better performance when things get wet and muddy. It was worth the cost to me.
    I can't compare them to hydraulics at all.
    mbtr member
    Reputation: scottzg's Avatar
    As a brake, they're very good. There are hydraulics that, as a brake, are very bad. Therefore bb7's are better than some hydro brakes.
    They're easy to set up and fix and offer good and very consistent performance. If those are the most important attributes for a brake to you, i doubt you could do better. If weight, or lever feel, or cost, or power, or no daily maintenance are more important... there's other brakes on the market that would better suit your desires.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Old man on a bike
    Quote Originally Posted by Squash
    Good Dirt
    Dang that's good. Should be a sticky.
    suum quique
    Reputation: brentos's Avatar
    I have both BB7's and Ultimates
    The BB7's have impressed me by braking stronger on my 29" bike than my Juicy Ultimates with sintered pads do on my 26" bike. Modulation is comparable. Both are set up with a pair of stock 160mm rotors.
    I have to adjust the BB7 on a much, much more frequent basis than the Ultimates and they do weigh more.
    Oct 2007
    you have to frequently adjust bb7's by design. if everything is working as it should, you'll be making frequent adjustments. hydros do not need to be touched, by design. just hop on and ride, the brake does the rest. you'll occasionally need a bleed or flush, which is easy.. mech brakes will occasionally need cables and housings replaced, which is easy.
    hydros are easier to setup and maintain. the bb7s arent bad, but they need to be adjusted. they have plenty of power and modulation, but they feel like cable brakes. some people like them, the overwhelming majority of everyone else has hydros and isnt changing back.
    disc brakes need to be broken in to actually work too.. so if you take a spin on a brand new bike, the brakes will always feel horrible. try to find someone with a well broken in set of hydros and bb7's and see for yourself.
    Tomsmoto,
    I installed new brake lines and new levers (Avid Speed Levers) and my brakes feel several times stronger than they even did when new! The problem is they are so strong that I don't have much feel to them. They act like an on/off switch and I only need slight pressure from one finger to lock up either wheel. What should I do to improve modulation? My current setup: Avid Speed Levers, XTR brake housing, BB7 calipers, G2 rotors.
    ^^^^^ All good notes. As a direct comparison, I rode bb7's on my HT for years. J3's came on my ex7. The BB7's have better stopping power than my J3's, however I'll take the J3's because of the feel at the lever, predictablity, and lack of maintenance/tweaking. I ended up going with a larger rotor on my front j3 and now the performance is better, but still doesn't have the shear stopping power of the BB7's. W/ the stock 6 or 7" rotor on my HT the J3's would have been money as I wasn't going down nearly as fast as I do now on my FS.
    On MTBR hiatus :(
    Quote Originally Posted by willevans
    Will,
    First things first, back off your inside (fixed) pad one click at a time, until the operate with the modulation you desire. This adjustment effectively "detunes" the brakes from max stopping power.
    Secondly, adjust your Speed Dial adjustment so the cable carrier is closer to the pivots. Actually, maybe you want to do this first, since it's a truer modulation adjustment. However, the first step I suggested has a bigger impact on how the brakes operate, and you should make yourself familiar with exactly what the inner pad adjustment changes.
    Lastly, play around with your outer pad adjustment so that the brakes "bite" when your fingers are in the optimal position. If you follow Avids setup instructions, the brakes engage very early, when your fingers are still outstretched. This isn't necessarily the best position from which to to modulate a brake.
    speedub.nate
    MTBR Hiatus UFN
    Mud lover
    I don't doubt that good hydros will walk all over BB7's. But for bang for the buck the BB7's are very hard to beat.
    I had a go on a friends Scott that had J3's on it. I hated them. They felt like mush. This bike was set up by a very experienced LBS btw.
    So I think that at the low level the BB7's are well worth the money. I would also trust mechanicals more for long distance riding mainly because of the issue of roadside maintenance.
    Speedub.Nate,
    Thanks for the feedback! I'm going to try your suggestions this afternoon. Setting up the BB7s as described by Avid makes them rediculously strong, especially with fresh cables and levers. I'm 210 lbs and I ride a 30 lb bike with only 160mm rotors and these things SNATCH my bike to a stop like a dog at the end of his chain!
    Feb 2006
    There are many other threads in the brake forum where some of us here discussed the BB7, modulation, best Speed Dial setting etc.. Everyone seems to have his own favourite setting. I would like to invite you BB7 owners to try the following "extreme" setup (if not yet tried):
    - both pads only one single click away from rubbing
    - Speed Dial full counterclockwise
    At first glance this is the setting for the ultimate brake power. Yes - but in my opinion you get great modulation with respect to the tremendous power. Now you should feel a very early and predictable beginning of brake operation just after pulling the lever, but you have to pull a significant lever range up to the maximum power. It is't abruptly (no on-off feel) and with a linear range until you reach the maximum.
    Some friends with hydros (Formula Oro, Avid Juicy...) who swapped their bike with mine were impressed by this brake performance!
    Would be nice to hear some comments how this setting feels for you (please practice before commenting).
    My experience is that hydraulic models with so much power (e.g. a Juicy 7 with larger rotors and Swissstop pads instead of sintered ones) have a much more abrupt braking curve.
    Quote Originally Posted by trelgne
    trelgne,
    My GF just got (a)nother) new bike, which came with BB7s. They don't seem to be stopping well at all (especially compare to the hydros on our other bikes). I don't know anything about these brakes, and I'd like to adjust them a bit. Which is the "Speed wheel" and by adjusting the pads "one click away from rubbing", is that the red wheel by the hub?
    Thanks.
    Quote Originally Posted by manowar669
    trelgne,
    Thanks.
    Yes. Set your bike so that both wheels can spin freely. Then (watch your fingers) dial in the pads until you start to hear some rubbing using both inside and outside red dials. You'll notice the engagement will be much faster and stronger. If not, take some alcohol and clean your rotors.
    I think the SpeedDial is the little red knob on the SpeedLevers (Avid) that allows you to adjust the leverage ratio of your brake levers to the amount of cable travel.
    knock-knock...
    you might want to hit the brakes a couple of times as you do that, especially if you are backing the pads out, just to make sure the pads are right against the piston.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    BB7s that are set-up properly are damn near as good as hydros, both in terms of feel and power.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    Coming from V-brakes initially, I loved my BB7s. The above posts are correct, at the lever they'll feel a lot like V-brakes, but with much better stopping power. Going on to Juicy 5s, I wasn't crazy about them at first, and I didn't like the lever feel. Now that I'm used to them, I really like the modulation and feel. But, IMO the BB7s are great brakes for the price.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Avid Mechs...
    It's all in the set up. Cable routing, housing type, pad adjustment, lever type; these all can make or "brake" the Mechs. The Mechs usually get a bad rap as they are speced on low end bikes, are set up with little attention to the details above, and are then maintained by the "low end rider" whose riding the low end bike.
    A "perfectly" dialed set of Mechs will rival a mid-range-priced hydro easily, performance wise.
    Set-up-wise and ease of maintenance they are impossible to beat. That's why I run them on my do-it-all, low maintenance, mule of a SS. They route wonderfully on KM frames. IMO this is where these brakes have their real niche, the low maintenance, "mule bikes", if you follow.
    Don't be fooled into thinking that they lack power. I use to run them on my DH bike. No they are not as powerful as a good hydro but they are good enough with the right size rotor.
    Compared to a top end hydro they are not as good performance-wise.
    Reputation: peternguyen's Avatar
    Quote Originally Posted by Miker J
    Yeah i agree, and to add to that, also consider when comparing prices as well, people are possibly forgetting that when you buy the BB7s you just get the caliper and rotor, whereas hydros you get the cable and lever as well (obviously it'll have to come with that). So you can think of it like this, when you get the BB7, they will be damn awesome but youll need to 'complete' the setup with also awesome cables and levers.
    Cables are often over looked, but getting quality cables will make a big difference. And if you can make your cables full length housing, then it will have the advantage like hydros in that it wont collect dirt. And also good cables will make the pull feel frictionless, smooth etc. Then theres the lever, which a good lever can influence the responsiveness, and can be adjusted for desired feel, reach, actuation ratio etc.
    In my opinion, a good setup and good combination of components to make the mechanical disc setup will make the brakes perform superbly, then beyond that it becomes user preference if they like the 'mechanical feel' or the 'hydraulic feel'.
    Feb 2006
    Which are these good or top end hydro models that have more power than a BB7 with maximum power setting (that is: Speed Dial full counterclockwise, both pads only one click from rubbing)? Of course I speak of same rotor size and same or comparable pads. Up to now I haven't seen a hydro that could rival with my BB7 in the front. I've tested: Magura Julie, Magura Louise, Avid Juicy 7, Formula Oro K18, Formula Oro Puro, Shimano LX, Magura Louise FR, Giant MPH3.
    Just sold my J5s to get some BB7s/Speed Dials/Generic compression-less housings/steel cables. I run 185 fr /160 rr clean sweep rotors.
    Let me tell you, the BB7s are amazing. The power is there, but really satisfying that the modulation is fantastic. I use one finger down the steep, rocky, wet single track and can modulate the front so the tire doesn't slip. Its really confidence inspiring.
    The real reason I went back to BB7s from hydros is that I run two wheelsets and I didn't have the discs *exactly* lined up. I used some spacers and got them within < 0.5 mm of each other, but the J5s still hated me. I'd have to loosen the mounting bolts and reseat them (multiple times) each time I changed wheelsets. With the BB7s, I just drop in another wheelset, and have a few quick turns of those red dials and I'm back in business.
    I have had BB7's on both of my mountain bikes for the past year. I have had 2 sets of hayes 9's and one set of shimano xt (on dual control) brakes in the past. The hydro's were great, but the BB7's have held their own and are an all around fantastic brake, when set up right.
    Like the other posters said set up is crutial with these brakes, they can feel like the worst brakes in the world, or pretty close to the best. I have mine set up with both pads pretty close to the rotor, and power is fantastic with my FR 5 levers. (granted I am on a sub 20 pound hardtail, or my 25 lb 29er). I have found no need to get bigger rotors for these brakes, and have been really happy with them. And for the price you can't beat it!! (what other brake is there that you can spend less than $120 bucks for levers lines calipers and rotors that works this great)
    (I am getting a set of juicy ultimates to repace the BB7's on the race bike)
    I just ordered some BB7s with Speed Dial 7 levers to replace the Juicy 3s that came on my bike. I just bought my bike less than 3 months ago and the front brake has already lost a ton of stopping power, even though I really haven't ridden it that much, so I figured I'd simply get some BB7s instead of having to hassle with the J3s (and probably getting nowhere). I guess I could have bought a bleeding kit or had my LBS bleed the brakes, but who knows how short it would have been until the J3s would need to be bled again.
    I like bacon... (clyde)
    Reputation: SpyderPride's Avatar
    Liquids are typically modeled as incompressible, because they compress very little compared to gases. However, they do compress.
    (edited)
    Bike: '08 Trek 6500
    Color: Oreo
    Delicious...
    I have the BB-7's on a Misfit rigid singlespeed. I bought mine BB-7 brakes from Bluesky and they came with the G-2 rotors. As everyone else had mentioned its all in the set up. While I probably spent as much as a decent set of hydro's I wanted the simplicity. I used the Avid Ultimate levers and the Alligator I-Link housing and cables front and back full length. After breaking them in I have not had a adjust the pads once. The 160mm pads give much better braking over my Avid Ultimate V-brakes on my 26" Zaskar. I have the brakes start to grab about 1/2 way into the pull and the modulation is excellent. I think way too many folks try to set up instant brake engagement and don't take advantage of the leverage created by the lever when you allow the lever to pull more cable before pad contact with the rotor.
    Higher end hydros may be better but the BB-7 brakes work so great for me that I really don't feel the little to be possibly gained is worth it. I think in the long run the mechanicals will have a lesser chance of a failure. My .02.
    I currently have BB7's on my bike with Alligator serrated rotors and Alligator ceramic sintered pads. Also got the Avid full metal jacket cables running. I set them up using this guide on the net:
    http://www.twowheelblogs.com/unit/av...-up-and-tuning
    It's an even better guide than the video on YouTube.
    My brakes are dialed in great, and have more than enough stopping power for the trails I ride. I think BB7's are amazing for the price - especially if you already have some good Avid SD levers laying around.
    However, they'll be off my bike in a few days. Why? Because my wife bought me Formula Oro Puros as a gift Hopefully the MTBR 5 star rating on the Puros is well deserved!
    Reputation: kirbster1966's Avatar
    One great think about the BB7's that are overlooked is the easy ability to set them up between wheelsets. A click here, a click there and you can eliminate any rub. Hydros require you to undo the caliper bolts and re-seat the calipers. I had BB7s and have two sets of wheels , one with slicks for the road. The disk mounting was off between the wheelsets just enough to cause a bit of rub. With the BB7's it was literally 30 seconds to get them all adjusted where i liked them. I now have Juicy 7's, and until i recently got a dedicated road bike, was really missing the easy set up of the mechanicals. The feel and modulation are definitely better with the Juicy's but power wise there was not much if any difference at all.
    Ask me About O Rings (Check the Classified section)
    Quote Originally Posted by kirbster1966
    Oh really? I knew and liked the fact that the BB7 are really 'adjustable' but in terms of just 'aligning' i thought with the hyrdos they 'align' themselves from squeezing the lever. Maybe im wrong but i remember reading this somewhere, perhaps for a particular hydro.
    Quote Originally Posted by peternguyen
    I know my low end hydros are like this, but I would hope that nicer more expensive models have adjustment knobs for aligning the caliper. It is true that the system will adjust itself in terms of pad wear, but it will not align itself. If it gets knocked out of alignment for one reason or another, the entire caliper needs to be moved which requires manual external adjustment.
    Bike: '08 Trek 6500
    Color: Oreo
    Delicious...
    Keep on Rockin...
    Nov 2003
    Well....
    Funny, you don't mention Hayes.
    My 5 year old Hayes Mag Pluses have more perceived power with equal sized rotors. Not a lot more power but me thinks a bit more. Hayes are known for their on-off, grabby feel so that plays into it as well. "Grabbiness" sometimes gives you the feel of more power without having more actual stopping power.
    Don't get me wrong, the Avids have power. I ran them on my DH Bullit back in the day with an 8 out front and a 6 out back and rode many miles at Diablo with that setup. Anyone who says Avid Mechs "don't have enough power" ain't setting'm up right. I've been running the Avids with Ultimate levers and the Mech setup is D-I-A-L-E-D.
    It really is quite an subjective affair and I would expect the OP to take it all in as opinion.
    No rights or wrongs here and its almost as bad as comparing saddles or even the best color of bikes (even though clearly the discontinued WTB SST saddle and a red or black bike is best, trans-red that is, with a polished swingarm....).
    dreaming of bottlerockets
    Reputation: Excel's Avatar
    May 2005
    I know there are weights posted all over the place, but does anyone know the weight difference between running BB7's w/160mm rotors and a similar hydro system?
    I did really well on the X/C race circuit this year, and disc brakes coupled with a high-end wheel-set will help me out quite a bit - raced on an old, but fast+light hardtail last year.
    I need enough of a reason to justify the cost of hydros if they save a significant amount of weight vs. BB7's. V-brakes are good, but they just aren't cutting it even with Kool Stop Salmon pads.
    I'm familiar with disc brakes otherwise (run them on another bike), and I can get used to any braking system given enough time on the bike.
    if it ain't broke you ain't ridin' hard enough
    http://www.outdoorsclub.ca - I'm the webmaster and I help run trips!
    Suffers From Binge Biking
    Reputation: marsh rider's Avatar
    Inconsistent Pad Spacing
    I didn't want to start a new thread just to ask my question since there's this active one about BB7s, so I hope you don't mind if I jump in here. I just bought and installed some BB7s and noticed that on both the front and back calipers, the pads wouldn't sit even from the front of the pad to the back. There is a difference of 1/4mm in spacing change between the pads (one click= about 1/16mm), and the pads contact the rotor at an angle so I can't get the pads as close as I'd like without them rubbing. Is this normal, or am I just being overly sensitive? Or both?
    If it ain't broke, fix it 'till it is.
    Keep on Rockin...
    Nov 2003
    About.....
    Quote Originally Posted by Excel
    About 25 to 50g per end. Something folks don't get when comparing brake weights. Companies touting their brakes as light weight often get that savings from the rotor, not the caliper, lever, hoses... Avids seem to come speced with some of the heaviest rotors I've seen which accounts for much of their weight.
    Last year I picked up a set of "middle of the road" Hayes Carbon HFX 9s on a blowout sale. Minus the rotors, the weight difference between those and the Mech set up was insignificant. I sent them back.
    1/4mm is 0.01". Just kick it...
    If you're saying 1mm on one side and 4mm on the other, sounds defective or mounted wrong somehow.
    Bike: '08 Trek 6500
    Color: Oreo
    Delicious...
    Mud lover
    Which directional angle are they going at? Up and down, or forward to back? Is it a constant rubbing or an intermittent one?
    My little BB7 resource.
    How to setup the Avid BB7
    Quote Originally Posted by marsh rider
    You most likely need to re-align the caliper using the CPS bolts. Another way of aligning the pads is instead of turning the dial to squeeze the rotor (like it says in the manual and video), is to squeeze the brake lever, and hold it while tightening the CPS bolts, though this might be harder when aligning the rear caliper. Anyway, i found this to be a better method than what the manual said.
    Mud lover
    There shouldn't be much difference in the methods. Holding the brake lever seems a bit awkward and wouldn't really gain anything. I've collated a load of the info I have found over the last year or so at the website in my sig.
    Nov 2007
    Quote Originally Posted by SpyderPride
    Squash-
    All good until this:
    If this was true, we'd bleed our lines with water. Liquids compress, some more than others. Liquids are typically modeled as incompressible, because they compress very little compared to gases. We use low compression oils for hydraulics, such as DOT fluid (engineered to compress very little) and mineral oil. I just don't want a non-technical person walking away thinking that all liquids absolutely do not compress.
    Actually, although water is not completely incompressible, for the purposes of bike brakes it is. We could put water into a brake system designed for water, if it wasn't for the low boiling point (and high freezing point) of water. With only a 100C boiling point, any amount of heat would boil the water and create gas in the lines.
    Quote Originally Posted by lyndonchen
    You're right. I was just trying to make the point that all liquids compress, even if it is a very small amount. My bad.
    Bike: '08 Trek 6500
    Color: Oreo
    Delicious...
    Thanks everyone for your help... it was just poor alignment Before getting the brakes I read all the posts on here about setting them up just so I could get it right the first time but still managed to mess it up. I ended up re-doing it using Simon's website (thanks Simon!) and now have the pads much closer. I like working on my bike upside down (the bike, not me!) since I don't have a stand and noticed something this second time mounting the caliper. When I loosened the CPS bolts and then clamped the pads to the rotor, the caliper was hanging down away from the frame just a bit, so when tightening the CPS bolts, I would be forcing the pads across the rotor with full clamping force. This might have had something to do with the mis-adjustment the first time and could possible have caused the slight warp in my rotor.
    Nov 2006
    Loosen bolts, squeeze lever, tighten bolts. This takes 20-30 seconds depending on your mechanical aptitude.
    my marta sl's are far superior to my BB7s, IMHO. i was a real shill for the BB7s until i got some nice hydros, and, well...i've seen the light. yes, the BB7s are well set up...full-length housing, kool-stop pads, max-leverage at the SD levers, etc.
    that said, the BB7s are better than any other mech disc or linerar-pull that i've ever used...stronger, better modulation, far better performance in the wet.
    if you're looking to save coin, the BB7s are the ticket. if you can spring for nice hydros, i certainly would.
    Hydros adjust themselves automatically for wear, but they still have to be set up properly in the beginning in order to work properly.if the disk centers differ between wheelsets, you have to re adjust the calipers on hydros. With the the BB7's you can easily adjust the inner and outer pad clearances in just a few seconds.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Use washers between the hub and the rotor to space out the rotor to the same position on both wheelsets.
    Would anyone like to trade my Hayes 9 hydraulics for mechanical disks?
    I find mechanical systems to be a little more straight forward given my lack of experience with hydraulic brakes.
    The Mud Stud
    Reputation: Dirt Bringer's Avatar
    Good Dirt
    Wow, thank you. Excellent detail. Will remember that, have been looking for that kind of info for a long time.
