Sorry if this is a repeat – couldn’t find anything on the forum.
Under hard pedaling climbing my rear BB7 squeals loudly. The harder the pedaling the louder the squeal. I am fairly sure it’s the (rear) brake because I can reduce the squeal by engaging the brake (perfect solution when climbing hard…)
It seems like an adjustment –any recommendations?
Thanks.
check your QR in the back and make sure you lined your rear wheel up straight. Happened to me with a different brand but found the extra torque to move the wheel and disk enough to cause it to squeak.
Sorry if this is a repeat - couldn't find anything on the forum.
Under hard pedaling climbing my rear BB7 squeals loudly. The harder the pedaling the louder the squeal. I am fairly sure it's the (rear) brake because I can reduce the squeal by engaging the brake (perfect solution when climbing hard…)
It seems like an adjustment -any recommendations?
Thanks.
Is the bike a hard tail or full suspension? Has any work been done to the bike before it happened, or have you had a bad wreck lately?
It sounds like you have something loose or damaged that is causing the rubbing under heavy load such as climbing. I would go over all the bolts on the brakes (make sure to check the rotors as well) making sure they are tight, also check the brake cables, housing, and levers for any damage, loose parts etc. Lastly check the rear wheel make sure it is tight, you may even want to pull the wheel off and check the pads. If you do find anything loose, I go through and redo the alignment/setup on the rear brake.
Worse case turn the bike upside down and yank on the rear triangle and check for excessive flex, from either frame damage or a loose swing arm.
I'd take the pads out and bend the retainer clip/spring thing some to make sure the pads are kept away from the disc except for under braking. It may be getting weak and letting the pad rub the disc. Playing with the QR and adjusting the brakes may help too.
check your Axle and Hub, make sure the bearings aren't loose. Particularly if it's a loose bearing style hub.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
