    BB7's, Rotor Size, Adapters
    I am currently running 2003 BB7's with 160mm rotors. I destroyed the rear brake and it needs replacement. If I buy a new 185mm or 203mm version of the rear BB7, can I install the larger disc and mounting bracket in front (on a 2003 BB7) and keep the 160mm in rear?
    If so, would you guys get the 185 or 203mm front rotor (I'm 200lbs and it's my all mountain hardtail)
    Was the rear adapter trashed too? If so, just buy a 185 front remove the trashed brake. The brakes are all the same, it's just the adapters that are different.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    ^^^ yup!
    Honestly... ahh I give up
    Awesome -- thanks a lot (the adapter survived...the adjuster mechanism froze due to salt corrosion and I managed to break it trying to unfreeze it)
