Results 1 to 3 of 3
    New question here. BB7 users: inner cable dia. 1.5/1.6 mm compatible?
    Dear BB7 users,
    I noticed there were two diameter specs 1.5 (Jagwire etc) /1.6 mm (shimano) for brake inner cables the other day. How about casing? I mean casing hole dia not outer dia...
    If I use Shimano inner (1.6mm) and Jagwire casing ( 1.5mm hole???) combo for running BB7, it would make more brake drag???
    Any thoughts?
    -Aki
    "Semper Farcisimus!"
    Huckin' trails
    Reputation: David C's Avatar
    If the cable is sliding easy by hand trough your housing, then it shouldn't be a concern. Usually the inside diameter of brake housing is over 1.6mm, to allow for room where the housing actually curves. The only thing that might be an issue is the ferrules (housing stops) opening diameter, mostly in the case of sealed or nosed ferrules, where they are designed to fit very snugly over the inner cabe to prevent any dirt to enter the ferrule and housing. Make sure everything is aligned and check for any unusual cable friction by moving the cable by hand.
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    David,
    Thank you for reply. OK, I will check ferrules then do handy test of sliding housing.
    -Aki
  1. Naked Shifter Cable or Full length Cable Housing?
    By Scott Novak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2013, 04:02 AM
  2. Replies: 1
    Last Post: 04-16-2013, 06:20 AM
  3. QBP cable housing $1/ft; Sram Derailleur cable $2/set; free ship over $30
    By bob13bob in forum Where are the Best Deals?
    Last Post: 03-29-2012, 06:51 AM
  4. How many Sram users run the Gore sealed cable system?
    By customfab in forum General Discussion
    Last Post: 12-13-2011, 11:28 AM
  5. Replies: 1
    Last Post: 03-04-2011, 06:48 AM
