Results 1 to 3 of 3
    Are BB7 Rotors compatible with Avid Elixir CR?
    Title says it all. Will my other wheelset with BB7 rotors work with my Avid Elixir CR brakes.
    Cant seem to find this info anywhere on the web?
    dirtbag
    Reputation: ranier's Avatar
    Sep 2003
    Rotors are rotors. As long as the caliper matches the rotor size, ex 160mm, 185mm etc they'll work.
    Amolan
    living in forever land
    Reputation: ultraviolet's Avatar
    the braking surface is the important thing you need to worry about, most avids brakes and around about the same braking surface so you should be ok
    "the sanctity of this agency requires the loss of a few personal freedoms...."
