    Reputation: Tincup69's Avatar
    Sep 2012
    BB7 question. 160 or 180mm?
    I'm replacing the BB5's on my Mukluk with BB7's and I'm wondering about rotor size. I'm 5'11 and almost 220lbs and ride some pretty steep terrain. The BB5's just aren't cutting it. Should I go with 160 or 180mm rotors? I'm assuming it's just plug and play once I get the proper adapters for the 180's if that's the way to go?
    Thanks in advance.
    2016 Trek Farley 7
    2015 Specialized Fatboy Comp
    2014 Trek Fuel EX8
    2015 GT Grade 105
    Reputation: Bald_Ben's Avatar
    May 2005
    I'm 175 and noticed a big improvement when I upped the front rotor on my hardtail to a 180. I would definitely recommend it, and you should be fine keeping the 160 out back. You're correct re: adapters.
    "A thing is right when it tends to perserve the integrity, stability, and beauty of the biotic community. It is wrong when it tends otherwise." - Aldo Leopold
    WillWorkForTrail
    Jun 2012
    Go 180, and yes, with the correct adaptor everything will just go right together.
    Oct 2013
    i run bb5's with 180's and it made a huge improvement. using swisstop pads made another huge improvement (when raining or when it gests sandy, aftermarket organic pads make the brake perf remain more consistent imo).
    i'm about to put ripcord and speed dials on my bike, it should improve even further the control i have on these brakes.
    @op, why take bb7 and not spyres? about the same price but spyres bite both side of the disc.
  1. want to go fro. a 180mm front rotar to a 203mm question
    By whiterider in forum All Mountain
    Last Post: 04-17-2013, 05:58 PM
  2. 180mm on EG V3?
    By kenny78 in forum Titus
    Last Post: 10-17-2012, 11:32 AM
  3. Fox Van 180mm RC2
    By rugbyred in forum Downhill - Freeride
    Last Post: 06-20-2012, 09:44 AM
  4. 180mm rotor question
    By Gilly32 in forum Brake Time
    Last Post: 04-16-2011, 08:19 PM
  5. 180mm on an SS1?
    By Decklogic1 in forum Intense
    Last Post: 02-08-2011, 01:17 PM
