Results 1 to 9 of 9
    BB7 Pad Catching on Cleansweep Centerlock Rotor
    As the title indicates, the tab on the inside pad catches on a 165mm Avid Cleansweep centerlock rotor. Is it ok to clip the tab off? And if so, how do I remove the pads?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by bigzebra
    Can you bend the pad tab?
    mtbtires.com
    No, I can't bend the tab. It looks as though the tab is resting against the body of the caliper. I suppose I could file a groove in the tab to allow for enough clearance.
    Here's an obligatory crappy cell phone pic:BB7 Pad Catching on Cleansweep Centerlock Rotor-img_20100925_145511.jpg
    Dec 1998
    Here's an obligatory crappy cell phone pic:Click image for larger version.
    Just cut it off. To replace retract the pad adjusters completely, remove the outside pad first, then use needlenose pliers.
    mtbtires.com
    tough guy
    Reputation: khoalie's Avatar
    agree w/shiggy, just cut them off.
    Hates rain
    Reputation: mike11204's Avatar
    Quote Originally Posted by khoalie
    +2 Cut it off.
    I cut it off (leave enough to remove with needlenose pliers) for my Juicy 7's with Shimano centerlock rotors.
    I can't believe Avid did the same thing.
    Jul 2003
    Yes you can....
    easily clip off that tab with no ill effects. It's a common practice for using the BB7/Juciy pads with center locks. The only thing the tabs are there for is to make getting the pads in and out of the caliper easier. However they are not essential. So clip it, cut it, grind it off with a dremel, problem solved. Just remember to do it to a new set of pads when it comes time to replace em.
    Good Dirt
    Clipped the extra material off today. Problem solved!
    Thanks!!
