Results 1 to 7 of 7
    Reputation: jamorgan3777's Avatar
    BB7 compatibility with older XT shifter/BLever combos
    I have a set of older XT shifter/brake combos currently running cantilever brakes. Can I run mechanical disc brakes with these? They are in good shape, just dont know if they are the right "pull" for mechanical discs (they can't be used with V brakes, right?)
    Thanks.
    Nov 2007
    Someone will correct me if I'm wrong, but I'm pretty sure you need v-brake levers.
    Meh.
    Reputation: XSL_WiLL's Avatar
    You'll need to use a travel agent with BB7 MTN brakes. Or use BB7 ROAD brakes.
    Cantilevers use a different pull.
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by jamorgan3777
    Thanks.
    Are you talking an older set of integrated brake levers/shifters in Shimano XT as in 2002-4 or older than that?
    BB
    Older than that
    Older than that. These are from a GT avalanche that is from ~1998.
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    Without knowing the exact model year, you'll have to locate a model number.
    ST-M738 = cantilver brakes only
    ST-M739 = V-brakes only.
    Jul 2003
    "Without knowing the exact model year, you'll have to locate a model number."
    He already said the bike is equiped with cantilever brakes. So it stands to reason that the levers are for cantis, right?
    To the OP, yeah, as XSL_WiLL noted, you'll either have to go with an adapter like the travel agent, or go with BB7 Road calipers to make em work properly.
    Good Dirt
