Hi,
I found a problem with my 2012 XX brake today (new)
Trying to adjust the lever reach with the 3mm hex key in behind the pivot. The fitting just spins and spins, something is clicking when it's spinning too but the lever doesn't move at all...
Shop has agreed to send it back to sram, but just in case it's an easy fix, any thoughts on what it could be ? The brake appears to be working fine.
