Results 1 to 2 of 2
    Jul 2013
    Avid XX lever problem
    Hi, I have a problem with said lever in my gf's bike, I think. The bike's been unused for almost a year now and I noticed that the rear brake is stuck. The lever only moves a little, the pads rub against the rotor but don't move at all. The front lever might've been pushed without the wheel in place when hauling the bike in my car. Anyway, I tried to bleed the system but was unable to push fluid through either end. Tried removing the hose from the caliber, no fluid coming through when pushing the lever so I'm thinking there's something stuck inside the lever? Can I do something about it myself or should I just send it to a bike shop for repair?
    Thanks in advance!
    Jul 2013
    Hmm, so the lever works and if I take the hose of the caliber and push fluid through the bleed screw it comes through the bottom of the banjo bolt, but if it's attached to the caliber there's this resistance and nothing happens. With the hose attached to the lever nothing comes of the banjo. How can the banjo get stuffed up?!
  1. Avid Elixir CR Lever Issue
    By sasquatch rides a SS in forum Brake Time
    Last Post: 08-10-2012, 01:22 PM
  2. Avid Elixer 5 lever reach
    By stygz1 in forum General Discussion
    Last Post: 04-09-2012, 10:05 AM
  3. Avid XX lever reach problem
    By Tiffster in forum Brake Time
    Last Post: 02-10-2012, 12:48 AM
  4. Avid Elixir lever problem
    By torosc in forum Brake Time
    Last Post: 11-03-2011, 06:02 PM
  5. Lever clunk in Avid XO's
    By drewgold in forum Brake Time
    Last Post: 05-25-2011, 05:59 AM
