Results 1 to 7 of 7
    Reputation: yourideit's Avatar
    Jan 2009
    avid ultimate sl
    do i order elixir pads when it's time to replace?
    "if you can't be good, be good at it."
    nope, just regular Juicy pads.
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    I think I know where you're coming from here. The other day I saw a set of Juicy Ultimates or similar designation that definitely had the same apparent calipers as my Elixirs and definitely used the same top loading pads as mine. It had Juicy master cylinders. I think it was on an '09 top-of-the-line Specialized carbon Epic. Now, I know that all Ultimates definitely don't use Elixir calipers, but there's some kind of mix/match deal going on out there, and it may just be in some OEM setups. What I saw was definitely a factory setup and not done by the bike owner.
    Jan 2009
    thanks tnc. yeah this is also on a specialized. it uses the top loading pads like you said. is there another type of pad out there that i don't know about for what they are calling the "ultimate sl." i just ordered elixir pads so we will see. sure looks like the right one.
    TNC
    TNC is offline
    noMAD man
    I'll bet you have what I saw, and I'll bet the Elixir pads will fit. None of the more common Ulitmate calipers have top loading pads, do they? I'm asking, not claiming to know absolutely. Can you post a pic?
    Jan 2009
    the ultimate elixir?
    for sure a mix and match custom deal by spesh. the caliper says ultimate but....it's snot. elixir pads are on the way.
    Definitely need Elixir pads for this caliper
