Results 1 to 9 of 9
    avid sram xx brake drag w non oem pads
    Hey Folks,
    Had some sram xx (not 2012) that came off another bike
    Running a regular avid rotor (not the xx rotors)
    Super noisy so I check and pad material was spent and pad backing contacting rotor
    I tried Kool stop and trucker co pads
    I could not even get the rotor in the caliper w new pads Kool stop
    so i gave up and got some trucker co pads
    I forced the pistons back to flush with plastic tool, then screwdriver (carefully) on pad backings
    Even let out some fluid of the system
    The tool-less rotating "pads in" adjuster on the lever backed all the way out
    Does anyone know if the xx series expects an xx rotor (w alum carrier) and that it's actually thinner than say a standard rotor
    Or do I just have to wait for pads to wear down on my commuter
    6 Rotor is fairly true but fork alignment is fairly wonky Kona rigid dj fork with locking skewers and washers to make up for the recessed sections (i think fork wants a solid nutted axle)
    Reputation: dirtyjack's Avatar
    I would try bleeding them with a red bleed block in place. You should be able to run any pad made for Elixir. And the Cleansweep and Cleansweep X rotors are the same thickness. You might have to reposition the calipers too.
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    Reputation: Svard75's Avatar
    +1 ^^ almost always have to re-align the calipers with new pads esp pads that aren't OEM. The fact that you opened the system to let some DOT fluid out makes me think you probably got air in there now. You need to get the bleed kit and bleed your brakes.
    S
    Yup good idea, thank you
    I do have air in there now actually since when i put the bike vertical on my bike tree then put flat
    the lever hits the grip untill i pump it a few times
    but its my understanding that the avids are an open system? unlike the older hayes? and more like new saint or older gustav m (but I could be wrong)
    So air wont kill the brakes, but still not a good idea to have in there
    I have the bleed kit and need to find those red thingys
    I'll lube the pistons w brake fluid too and cycle them a bit too
    I think they look like this
    quick update
    bleeding helped with the air i introduced into the line, but even with the bleed block (i used the shimano yellow one since the other one was on order) was still getting a lot of drag
    So much so that the front wheel would stop if doing a short wheelie
    Once i got those red things, i jammed the thin part in between the pads and loosened the bleed screw on top, pushed out some more fluid and was able to further push the pads into the calipers
    Finally! they are not dragging but need to see what happens on the commute today
    Next brakes will be shimano (I have zero probs the the saints)
    xx completely suck. Mine worked beautifully for a month, great initial bite, powerful, smooth, just awesome. And then they didn't work regardless of what i tried. Requires a perfectly true rotor and then maybe i could spin the wheel without rub but after a ride it would be off, stupid pistons dont retract correctly
    Yep, XX brakes are a drag.
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    If the pistons are all the way back into the bores and there is still drag, then the rotor may well be a fraction too wide for those brakes. The system will be setup for there to be the perfect pad/rotor gap with new pads and a new correct brand rotor of full thickness.
    The non oem pads could have some more material on them, but it would seem to make sense for aftermarket manufacturers to match the stock pad thickness for best operation.
    Tool
    Reputation: Pedalphile's Avatar
    Is there a chance one or both pistons are sticking? If so, it would allow you to push the pads apart, but after the first time you apply the brakes they would rub again. Unless someone overfilled the system while it had worn pads, you shouldn't have to remove fluid from the system.
    The 'pads in' adjuster on the lever does not affect the position of the pads. It only affects the lever position at which the pads begin to move. It's essentially a control for the amount of dead space in the beginning of the lever travel.
    Good luck,
    Pete
    I can barely get my mouth around it.
