Results 1 to 5 of 5
    Mar 2013
    avid speed dial ti lever replacements?
    is it possible to replace the levers for avid speed dial ti levers? i notice they have a pin that is mushroomed on both ends where it holds the brake cable end. if i broke the levers would need a brand new brake set? do they even make replacement levers for the speed dials? i've looked online but haven't found any
    thanks
    Reputation: logbiter's Avatar
    You could try checking the SRAM service area of the website for the AVID spare parts catalog, but IIRC they've only been doing spare levers for the new ultimates for a long while now.
    Probably cheaper to grab a set of SD 7's for $20-30 online or your LBS.
    [SIZE=1][/SIZE]
    IllumaDucati
    Reputation: Roadsters's Avatar
    You won't need replacement Avid levers because you won't break them. They are designed to bend in a crash, and if that happens, you will be able to just bend them back. I've done it with my Avid SL levers. They're great.
    Mar 2013
    cool thanks
    The "bend zone" is designed to bend... I had one where the blade cracked when I bent it back, just the nature of aluminum. Depends on how much its deformed in the crash. They aren't designed to be replaced with that mushroomed pin.
    [SIZE=1][/SIZE]
  1. Disassembly - Avid Speed Dial 7 Levers
    By KLF in forum Brake Time
    Last Post: 11-21-2012, 10:03 PM
  2. Avid Speed Dial 7 set up
    By Cormac in forum Brake Time
    Last Post: 04-05-2012, 07:37 PM
  3. Avid speed dial 7
    By yaqui316 in forum Beginner's Corner
    Last Post: 05-18-2011, 10:07 PM
  4. Avid Speed Dial 7 vs Speed Dial Ti levers
    By fireroad in forum Brake Time
    Last Post: 03-28-2011, 09:42 PM
  5. Avid Speed Dial 7 vs Speed Dial Ti
    By Call_me_Clyde in forum Brake Time
    Last Post: 01-14-2011, 02:03 AM
