Results 1 to 2 of 2
    Avid Single Digit 7
    My Trek 4300 came stock with Tektro V's. Will I notice a difference in stopping power if I upgrade to Avid Single Digit 7 rim brakes? Thanks.
    ...idios...
    Reputation: SteveUK's Avatar
    Almost certainly. With a good set of (properly cut/fitted) cables, the Avids should feel much better. They'll have less flex, will translate to better efficiency (more power, less effort) and better modulation. The SD adjustability will also enable you to dial them in to your own preference. If they don't come with them, see if you can pick up some KoolStop pads.
    Diogenes
