Results 1 to 5 of 5
    Sep 2004
    Avid SD Ultimate versus Magura HS33
    Hi,
    I am not satisfied with the brake power of my HS33 and would like to switch to the Avid Ultimate.
    Did anybody test both brake systems and can make a statement...
    Cheers
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Funny, but lack of power was never a comment I have heard associated with the HS33s. Normally they are considered to be noticeably more powerful than pretty much any other rim brake option (though some in the reviews section say it may be close with the Ultimates: read through the HS33 reviews). Have you tried other pads?
    My video techniques can be found in this thread.
    Sep 2004
    No, I havent tried different pads yet. But honestly I dont think this would increase the brake power dramatically!
    Some people say that the Avid V-Brakes are more powerful than the HS33.
    The Deore V-Brakes are honestly more powerful than my HS33!
    DHR Rider
    Reputation: Cohiba's Avatar
    Really?
    Quote Originally Posted by vindiesel
    I've tried almost all of the magura rim braking systems out there, starting with the HS-11 way back in the early 1990s. Even that system, when set up right, was able to provide more stopping power than V-brakes, particularly in wet weather. Also, it was important to use the proper brake shoes for your rim type, that affected performance also. And make sure you are using the newer, longer brakepads - the older ones are less than 1 inch in length! Another thing that affects performance is setup - Maggies' can be a pita to get aligned right (particularly the older systems with their "evolution" adapters), but once you have it dialed in, they almost never require readjustment again. Also put a brake booster on, particularly for the rear brake mounts... without em, the brakes made my chainstays flex like wet noodles, and the difference they made was astounding.
    Another thing is how people define "strong brakes". Just being able to lock up the rear wheel super fast is not an indicator of "good brakes". As you've no doubt found out already, modulation is key, or as Pirelli so rightly puts it "power is nothing without control". And I'd think Magura would get it right, since they've been around in the hydraulic brakes (and motorcycle brakes!!!!) business a lot longer than Avid has.
    In general though, unless you are a road bike, or cyclo-cross or hardcore XC rider, rim brakes are going the way of the dodo.
    Just my .02c
    Cohiba
    Reputation: 006_007's Avatar
    Hi,
    Cheers
    There is something very wrong with your setup if you believe v-brakes are stonger then the HS-33. Those are bar none the most powerful rim brake available. I have heard of people crushing rims with those bad boys when properly setup.
    check out the magura cult page for installation tips.
    http://www.execulink.com/~dtierney/w...a/contents.htm
    Also, are you running brake boosters? without them those brakes are so powerful they just flex the mounting posts......
    One last thing, if you do decide to get rid of them, let me know how much you want.
  1. Avid SD series brake bolts
    By Mep in forum Weight Weenies
    Last Post: 08-05-2004, 09:51 AM
  2. Wanted: Avid Ultimate cantilever brake levers
    By PMW in forum Vintage, Retro, Classic
    Last Post: 06-30-2004, 11:51 AM
  3. Magura Julie or Avid Mech
    By jakey in forum Brake Time
    Last Post: 04-19-2004, 11:27 PM
  4. Magura Julie or Avid Mech
    By jakey in forum General Discussion
    Last Post: 04-16-2004, 06:18 PM
  5. Avid to Magura? Would you?
    By heron in forum Brake Time
    Last Post: 02-18-2004, 08:51 AM
