Results 1 to 2 of 2
    Avid SD TI levers clicking
    Hi all,
    I recently installed some Avid Speed Dial Ti levers and I'm having a little problem of them clicking once when pulled.
    It seems to be coming from the little pivot point that you can see through the little cutouts. When tension is put on the lever, that pivot clicks a bit and slides towards the cable.
    This happens on both levers. Is this normal? Will it "break-in"?
    Don't touch me!
    Reputation: beeristasty's Avatar
    Are you sure it isn't the cable twisting?
    It took me forever to find out where my clicking came from. Turns out the cable was twisting inside its housing, causing the circular-cable-end-block-thingy to knock against its holder.
    If that is your problem, unbolt the cable at the brake and give it a little twist in the right direction, then rebolt.
    good luck
    Quote Originally Posted by Kevinv
    Hi all,
  1. drop bar levers and avid mechs...
    By 03bart in forum Brake Time
    Last Post: 06-22-2004, 07:34 PM
  2. Replies: 2
    Last Post: 05-23-2004, 06:18 AM
  3. Avid mech discs with XTR levers?
    By condoor in forum Brake Time
    Last Post: 03-17-2004, 11:31 AM
  4. new levers for avid mechs?
    By guava in forum Brake Time
    Last Post: 02-22-2004, 12:15 PM
  5. Avid Ultimates w/ Shimano XTR levers...
    By a4racer in forum Brake Time
    Last Post: 02-12-2004, 07:35 AM
