Results 1 to 3 of 3
    Avid road disc brake for mtb
    I just bought an Avid rear disc brake on ebay under the mountain bike section. The seller sent me the Avid rear disc brake for ROAD bikes. I checked the avid web site which states that the road disc brake should not be used with linear pull levers. The seller says that it can be used with linear pull brakes for "more pull".
    Anyone have any ideas on the compatibility of linear pull levers with avid ROAD disc brakes?
    Quote Originally Posted by K2footsrgn
    yeah, don't do it. you will have huge clearance between pad and rotor, but the brake lever will feel rock solid and you'll have precious little power. if you don't have integrated shifter-brake levers, then you can pick up some good canti levers for dirt cheap at any shop. slr plus levers with the shifters removed work extraordinarily well.
    tim
    Out spokin'
    Dec 1999
    Dump that chump
    ..."more pull"...
    More pull does not mean more power -- it means less. The road version mech caliper is designed to be used with road levers, which pull less cable than V-brake levers. So if you do utilize V levers with a road caliper your levers will ramp that caliper up immediately, allowing you very little lever throw before the lever becomes unbearably difficult to pull any further. In other words, you will have reduced your leverage AKA mechanical advantage. It will be very hard to lock up the brakes or even achieve power approaching lock up.
    I have a buddy that rides drop bars off-road and he's tried both types of Avid mech calipers on his 29er, road and mountain. He actually prefers the exact opposite of what you've described -- he likes a mountain caliper with his road lever. Lots of lever throw in advance of lock up, but plenty of fingertip power.
    Personally, I think you got a raw deal.
    --Sparty
    disciplesofdirt.org
  1. Adding Disc brake tabs
    By Dirteye in forum Brake Time
    Last Post: 05-12-2004, 01:06 PM
  2. Replies: 14
    Last Post: 02-06-2004, 03:49 PM
  3. Avid mech disc question...
    By DSR in forum Brake Time
    Last Post: 02-02-2004, 04:12 PM
  4. Racer X Disc Brake Mount
    By XC_Miles in forum Titus
    Last Post: 02-02-2004, 10:38 AM
  5. Avid Mech Disc Brake Tuning
    By baker in forum Weight Weenies
    Last Post: 01-23-2004, 11:18 AM
