Results 1 to 7 of 7
    Avid rear brake mount work with Shimano brake?
    Will my Avid IS rear brake mount for 160mm work with a Shimano M785 brake or will I need to purchase the Shimano mount?
    Just dawned on me that there may be some tiny difference that would make the brands not work with each other so figured I better check.
    B A N N E D
    It'll work but don't use Avid CPS washers with your Shimano brake.
    So ditch the cps bolts & use what comes with the Shimano brake.
    I met today who said he worked in a bike shop & said I'd need a Shimano mount. His friend was on BB7s & he was on Shimano so that reminded me to ask.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by bitewerks View Post
    There could be bracket/caliper interference. Otherwise it will work. If you have both the Avid bracket and the Shimano caliper, try it.
    mtbtires.com
    I haven't purchased the brakes yet otherwise I'd tried it out. The 160mm IS mount was the one thing I wasn't thinking about until now. I kind of thought it'd work since it is an International Standard but then recently thought "I better double-check".
    Dec 1998
    Get the brake.
    Try it on the Avid bracket.
    If there is interference, get a Shimano bracket.
    mtbtires.com
    It should work. Pretty standard. My front brake is slx with avid mount adapter. No problem at all. Rear mount should be standard as well, perhaps just need minor adjustment.
  1. Shimano brake SRAM shifter mount
    By Hophead1 in forum Giant
    Last Post: 05-25-2014, 03:13 PM
  2. Shimano brake adapter with avid elixir 5?
    By sambradley14 in forum Brake Time
    Last Post: 04-13-2013, 08:37 AM
  3. Replies: 4
    Last Post: 07-25-2012, 05:46 AM
  4. 2011 Avid bb7 disc brake work on my 08 GF Cobia?
    By Biggi_e in forum 29er Components
    Last Post: 07-18-2012, 11:27 AM
  5. Avid Post-Mount Adapter on Magura Brake?
    By Durga in forum Beginner's Corner
    Last Post: 02-03-2012, 08:54 PM
