Results 1 to 6 of 6
    Not dead yet, just playin
    Reputation: ohpossum's Avatar
    Avid polygon rotors. Worth it?
    Anything better about the "polygon" version?
    op
    www.msmtb.org - Mississippi Mountain Biking
    [paste title here]
    Reputation: mtnbikerdude87's Avatar
    Not really unless you like the look of wavy rotors. I like the look and I found a set for 10 bucks each. So I didnt really care if it worked or not. But so far its working fine. I dont notice any difference between the round avid rotors and these wavy ones.
    Keep Pedaling
    Do you have shuttering problem with the polygen rotors?
    What pads you are using?
    Quote Originally Posted by mtnbikerdude87
    Feb 2005
    Looks like the polygon shapes gets Avid out of the obligation to pay Galfer license fees for the wave rotor they hold the patents on.
    [paste title here]
    Quote Originally Posted by ohvina
    I am using the pads stock on the Avid Mech (I think they are the B4's) After 100 mi of using the rotors, I havent had any issue with shuttering. They seem to be working fine.
    Keep Pedaling
    Feb 2005
    That was designed to cure the up and down movement those thin wave rotor create in the pads. The brake track basically moves up and down in relation to the pads. The pads end up following and this creates the shuddering issues. Beveling the edges of the rotor may help to an extent, but it's simply the brake track moving up and down that caused it. The newer rotors don't have as much of the up and down because they're basically rotors with areas removed.
  1. Splined rotors... Shimano vs. Avid... Compatability?
    By MidshipmanX in forum Brake Time
    Last Post: 02-03-2005, 10:54 AM
  2. Anyone NOT having problems w/ Avid polygon rotors?
    By Simpleton in forum Brake Time
    Last Post: 01-09-2005, 06:19 AM
  3. Clean Avid disc rotors?
    By HTail in forum Brake Time
    Last Post: 07-18-2004, 12:40 PM
  4. hayes 8" rotors with avid mechanicals
    By Duncan in forum Brake Time
    Last Post: 05-04-2004, 06:43 AM
  5. Help w/ replacement rotors for Avid Mechs
    By ThornPatch in forum Brake Time
    Last Post: 02-03-2004, 02:23 PM
