Results 1 to 5 of 5
    Shortcutting Hikabiker
    Reputation: Acme54321's Avatar
    Oct 2003
    Avid pads won't go back in the freaking calpier .......
    Ok so one of my pads in my Avid mechs came halfway out when I was taking out my tire and now I cannot get the things back in. I don't know what's going on but they just will not go back in. I followed the directions but still nothing.
    This really pisses me off because it is a perfect day and I was about to go riding!! Grrrrr...
    HELP!!!
    Groveland Trail Heads
    Reputation: scheckler's Avatar
    Jan 2005
    Check the clip that holds the pads
    there is a small clip that holds the pads in place. My front brake's clip is different from my rear brake's clip but both perform the same function. I hope that helps.
    I changed some of this because I noticed that you mentioned they were the mechanicals.
    Oct 2003
    It's the rear. I am squeezing the pads together and pushing down like it says but they do not want to go in. I don't want to push too hard and bend the spring that holds the pads apart either.
    Jan 2005
    Are you seeing the clip
    Quote Originally Posted by Acme54321
    that I had mentioned?
    Oct 2003
    Nevermind I figured it out, I was trying to put it back together with the separation spring still in there.
  1. Current Avid disc pads?
    By HTail in forum Brake Time
    Last Post: 11-14-2004, 11:17 AM
  2. Some thoughts on pads for Avid Juicys
    By tscheezy in forum Brake Time
    Last Post: 09-30-2004, 01:04 AM
  3. Replies: 10
    Last Post: 07-13-2004, 07:52 AM
  4. Aztec pads for Avid discs: Extreme Danger!
    Last Post: 05-03-2004, 04:59 PM
  5. New Avid pads don't fit Rim Wrangler shoes
    By Dr.Faustus in forum Apparel and Protection
    Last Post: 04-29-2004, 01:04 PM
