Results 1 to 3 of 3
    MORC Member
    Avid Mech 185mm Disk, too much power...
    I have the 185mm Avid mechanical disk break on the front and it is way to powerfull. Even with a small touch to the brake leavers it brakes with a lot of power. Too easy to lock up the front tire... I've already went over the handle bars once because I accidently hit the front break while trying to jump a curb. So, what can I do go decrease the power? (Can't believe I'm asking that question, these brakes rock!)
    Do you live in Minnesota? Join MORC to help support our trials!
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by rpanning
    Turn the pad adjusting knobs out a click or two. Start with the outer pad.
    mtbtires.com
    Jm.
    Jm. is offline
    Reputation: Jm.'s Avatar
    decrease your leverage ajustment at the lever...if you have high end shimano or avid levers this is possible.
    I know in my heart that Ellsworth bikes are more durable by as much as double. AND they are all lighter...Tony Ellsworth
  1. How to use Avid 185mm rotor with Hayes Hydros
    By VT no 1 2 or 3 in forum Brake Time
    Last Post: 05-12-2005, 11:24 PM
  2. Avid 185mm compatible with Marz Z2 Atom?
    By luv2bikewny in forum Brake Time
    Last Post: 04-10-2004, 07:43 AM
  3. Help with Avid Mech 185mm setup with Fox Vanilla
    By BlackOut in forum Brake Time
    Last Post: 04-09-2004, 02:22 PM
  4. Best deal on Avid Mech 185mm fronts?
    By condoor in forum Where are the Best Deals?
    Last Post: 03-31-2004, 05:33 PM
  5. Mech Disk Brakes...Avid or Hayes???
    By BlurryTrees in forum Downhill - Freeride
    Last Post: 03-20-2004, 10:51 AM
