Results 1 to 8 of 8
    Reputation: Tiffster's Avatar
    Avid Lever removal
    Hi,
    I own some Juicy Ultimates. Without going into details i need to remove the levers - they will be removed for a couple of days. Will doing this let air into the system ?
    Finally can someone tell me how i undo the lever please ? All i want out is the lever itself nothing else.
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    u can remove the lever without letting any air in
    unscrew the lever pivot screw...push the lever pivot pin through (u may need to screw the reach adjustment screw in a little to get the pin out)....screw the lever reach adjust all the way in (lever will move away from the bar).....
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Formotion Products
    http://www.formot
    Hi
    So do i have to screw the lever reach screw all the way in so the lever is as far from the bar as possible ? OR just undo the other screw and push the pin out to remove it ?
    Calm Like a Bomb
    u need to screw in the reach adjustment (moves lever out) to just get the lever off without the pushrod and pushrod dust boot like in the pics
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    So if i take it out with the pushrod in place will that let air in ?
    Reputation: scooter916's Avatar
    Quote Originally Posted by Tiffster
    possibly, I would just thread the push rod out of the barrel and remove the lever blade and leave the push rod in the main lever body
    Meh.
    Reputation: XSL_WiLL's Avatar
    Removing the pushrod will not let air in... but you'll be fine leaving the pushrod in place.
    It's really not that difficult.
