Hi
Lever pulled to the bar, however it pumped up soon after and worked normally.
Should I just bleed them anyway?
CDT
(Stored upside down if that matters)
When I first installed mine this happened as well, if it has only happened once it was just the handle priming and now the pressure should be fine. If it happens again, then bleed the system.
Definitely the best place to start, the push pull with the syringes is supposed to free the air bubbles but doesnt always so it's good to tap any angles where the hose is snaking and banjo bolts/fittings. :yesnod:
If that doesnt work you know where to yell!! Double check that the pad spring is still in tact and the pads hasnt tried to drop. :smilewinkgrin:
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
