Results 1 to 3 of 3
    avid juicy three brake pads
    hi. i just bought a nice motobecane fantom pro29 bike off craigslist and bike looks good and all but i have one problem. the front brake pads for the disk brakes are like stuck i took off the front wheel and tried to put it back on but the brake pads will not open much. any help and on to adjust the pads so i can put the front tire back on would be great help thx
    sounds like you squeezed the lever when the wheel was off. to get the pads open again, take something wide (at least 1/2") and flat, like a butter knife or flat head screw driver, and work the brake pads apart until the pistons have fully retracted. be careful not to mar the pads.. put the wheel back in and squeeze the lever a couple times, and things should be back to normal.
    thx ill try that
