    Avid Juicy Seven Issue... Solution?
    Hello-
    Looking for some advice here. Mainly to see if most of you all do your brake work yourself or leave that to the professionals.
    I was taking out my pads to day to sand them a bit since they were glazed a bit. While putting the pads back in I was pushing the pistons in to “reset” them and I noticed fluid coming out from the reservoir in the lever area. Now that the pads are in there is no brake power at all.
    I have not done any research yet but seems like I need fluid and to bleed them. Thoughts?
    I have Avid Juicy Sevens and have had no issues other than this so far.
    himom!
    They will need to be re-bled. You'll probably should overhaul the lever - fluid shouldn't be leaking around there. How old is the brakeset?
    Thanks for the reply...
    The brake set is about 2.5 years old, on a 2007 Stump Jumper Elite.
    Looks like the fluid is coming from the part that has to philips head screws.
    The weird part about when I was pushing it pistons in was that they were pushing out after I set them back by themselves. This has never happened to me before.
    First set of hydros so not too knowledgeable with them.
    You have air in the system and a bad reservoir bladder/seal.
