Results 1 to 2 of 2
    avid juicy mechanics
    I messed up my avid juicy three brake. I broke the cone off that holds the brake pad in place. Are the parts on the caliper servicable or do I need to order a new one?
    Jan 2005
    easy fix you need to order new brake pistons or get them from the lbs .and get the old piston out by pumping the brake and then tae the calipar apart pop the new pistons in and bleed em up.
