Results 1 to 10 of 10
    Kearsarge crawler
    Reputation: minkhiller's Avatar
    Avid Juicy heads up
    Just to let everyone know. I am having a new bike built. My local bike shop informed me today that the brake line supplied with my new juicys is too long for my frame. Of course now he needs to cut the line drain it then hook it up and re-bleed the system. To do this you need to get a brake bleeding kit from Avid so if you are looking to get these sweet brakes for your bike give your shop a heads up. If you do your own work maybe you should look for the bleeding kit from Avid. Those of you who don't use brakes at all can disregard.
    simply me
    Reputation: bostonkiwi's Avatar
    Strange... the B4Pro/SL, Minis, and Martas can all have the line disconnected, shortened and reconnected without a bleed...
    mmm, carbon
    There is no need to drain the hose when shortening it. In fact if you were very careful, and your reservoir wasn't full of air, you could get away without a bleed too.
    thats my red stapler
    Reputation: jimjo's Avatar
    How Do You Do That
    Quote Originally Posted by bostonkiwi
    Is there another thread that decribes the process to do as such...or of you could be so kind as to post here
    thanks
    Official ***** Idiot
    Actually, it's in the Disk Brake Faq, which is posted to the upper right of the main page.
    Basically, install the brakes, calipers on the bike, levers on the bar. Now, disconnect the line from the lever, but keep it upright, and higher than the lever while removed. Cut to the appropriate length, and re-attach. No bleed necessary. If you're threading it through hose guides, keep your finger over the end, and make sure you don't spill any fluid.
    Jdcamb can support this.........I took the Magura Julies off my bike, put them on his brother's bike, and swapped levers, not only from moto to regular, but also from composite to alloy, and didn't need to bleed, add fluid, or otherwise adjust.
    Just be careful, that's all.
    Kearsarge crawler
    Good advice
    Thanks guys, I'll let my shop in on the advice.
    mmm, carbon
    Of course with the juicies you can't just cut the hose and reattach it straight away. First you need to force a new hosebarb into the end of the hose. This took a bit of effort when shortening my hoses, YMMV. Since I was bleeding them anyway, I wasn't too bothered about a bit of spillage.
    Kearsarge crawler
    That must be it
    Quote Originally Posted by Timbo
    I assume this is the problem my shop ran into, I have not spoken to the in depth.
    Feeding your addiction
    Reputation: Ventanarama's Avatar
    Dec 2001
    Yeah, it's typically not a problem at all with the Juicy. I've shortened lines on 6 pair of them so far, and only had to bleed one front brake (and that was only because I accidently bumped the lever and it squirted fluid out). Of course Murphy's law will apply and the one time you don't have a bleed kit around is when you'll end up needing to bleed them.
    Larry Mettler
    http://www.mtnhighcyclery.com
    Some Assembly Required
    Reputation: man w/ one hand's Avatar
    Czech out th' "D-low" link, Holmes.....
  1. Hayes or Avid for the Fuel?
    By Spaz in forum Trek
    Last Post: 02-23-2004, 05:13 PM
  2. Avid Ultimates w/ Shimano XTR levers...
    By a4racer in forum Brake Time
    Last Post: 02-12-2004, 07:35 AM
  3. Help w/ replacement rotors for Avid Mechs
    By ThornPatch in forum Brake Time
    Last Post: 02-03-2004, 02:23 PM
  4. Replies: 8
    Last Post: 01-20-2004, 03:20 PM
  5. Replies: 1
    Last Post: 01-13-2004, 10:47 AM
