Results 1 to 14 of 14
    dog's best friend
    Avid Juicy Carbon lever set screw leaps to it's death
    Well, I think that's what happened. Nevertheless it's missing. Luckily the lever pivot bolt(?) didn't fall out too. Anyone else had this happen?
    Attached Thumbnails Attached Thumbnails Avid Juicy Carbon lever set screw leaps to it's death-avid-juicy-carbon.jpg
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Over use of the lever caused it to back off, dont use the brakes.
    Formotion Products
    http://www.formot
    Reputation: 4slomo's Avatar
    A wise head bike mechanic once told me to use threadlocker on brake lever set screws, to keep them in place. I think that was probably good advice, learned the hard way.
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
    dog's best friend
    Anyone know a good online source for Avid brake parts. I'm 60 miles away from th nearestl bike shop located in Nelson BC..
    Jan 2005
    If your cool you can contact Hayes direct http://www.hayesdiscbrake.com/contact.shtml If you want to be a dyke check your LBS.
    Formotion Products
    http://www.formot
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Quote Originally Posted by dogonfr
    Contacting Hayes isn't going to get him very far with his Avid brake.
    Jan 2005
    Quote Originally Posted by Hardtails Are Better
    Thats his first problem Hayes would help him.
    Dont go their.
    Formotion Products
    http://www.formot
    Any decent hardware store should be able to hook you up. It's just a small metric thread grub screw. I would very carefully take out the set screw from the other side put it in a ziploc baggie so it dosen't get lost and take it along for comparison shopping purposes. It shouldn't cost any more than about 50 cents.
    Dawgwalker
    Loss of lever screw
    Same thing happened to my lever when it was new so I contacted Avids service direct. Although not enthused to deal with a customer rather than a shop they send me a repair kit, the screw is not available as a single item. Screw may be hard to find locally as it is a Torx head.
    2015 Turner Sultan
    2012 Moots MootoXZ
    2008 Turner Sultan
    2007 Dean Colonel 29r
    2003 Titus Switchblade
    Reputation: onegymrat's Avatar
    Same thing happened to me last weekend right before a descent (Juicy Carbons). Was a bit unnerving to say the least. I've contacted 5 different shops to no avail...no one seems to have any Juicy Carbons/Juicy 7s laying around to cannibalize for the pin. A shop has ordered the part for me through Avid and won't arrive for a few days. I've used some random bolt for now...which seems to work temporarily.
    On a side note, couldn't find a darn thing on the trail, along with 8 other riders to sufficient hold the lever in place that it would function normally. Closest thing was the clip of a ballpoint pen plus a zip tie jammed in there and I finished the ride.
    Jan 2005
    Guess its time to start carrying a magnet.
    Formotion Products
    http://www.formot
    Reputation: yeschiro's Avatar
    Bumping this old thread with the same problem
    I broke the original brake lever...but had a set of Juicy 7's that were broken while downhilling so I stole the carbon lever from that set to replace. Problem is, the pivot set screw was missing. Figured I could just use the one from the broken lever, but oddly it is not the same size (too small).
    The original lever had a deeper hole for the pivot set screw. The replacement lever has a narrow hole like in the photo above.
    I contacted my local Pleasant's Hardware and they claim to sell set screws, so I plan on heading over there to see if I can fit one...
    But since I saw this thread, was wondering if anyone was able to dig up the correct size for this specific lever to ease the search.
    Your bike is not the only thing that needs maintenance!
    http://www.yeschiropractic.com
    bikeaholic
    I lost both pins for my Juicy Carbons and ended up just using a screws and locking nuts from a hardware store. They don't fit as snugly as the original pins which makes the lever have a little bit of play, but they still work.
    Quote Originally Posted by dogonfr View Post
    Dont go their.
    Hayes brakes suck.
    If you were to recommend a new set at least throw out formula or shimano.
