Results 1 to 3 of 3
    Avid Juicy 7 parts search
    Where can I find the following online (no lbs has them)
    • Pair of replacement compression fittings
    • Pair of locking bleed fittings
    Thanks in advance.
    KITB
    Guest
    Quote Originally Posted by danK
    Thanks in advance.
    Speedgoat - and they're expensive. BUT, I went to my LBS after presumably being in the same position as you, -and got NON-AVID compression fittings and compression nuts (of way higher quality), went home, prayed, and the things worked. No leaks, nothing.
    The LBS had this "kit" of a bunch of generic hydro stuff, and I went through several different compression olives until I found one that was about the same size/shape as the Avid one.
    PS: the avid compression nut is a piece of dog crap. I barely torqued on it and it deformed and cracked. Becareful, or get new ones.
    Avid needs to include several compression fittings/hosebarbs in their bleed kits. IF you don't get a perfect seal on the first try, the olive is toast, and you gotta do it again. I burned through both olives on the rear brake and then was stuck, and about to go out of town the next day with my bike!! good luck.
    KITB
    Guest
    Thanks in advance.
    PS: I dont' know what you mean by "locking bleed fittings," unless you are talking about the interface with the clamp that attaches to the end of the syringes?
  1. Avid Juicy 7 vs Hayes El Camino
    By MTBdave in forum Downhill - Freeride
    Last Post: 05-07-2005, 09:24 PM
  2. Hope M4's vs Avid Juicy 7 which to buy?
    By BlackOut in forum Brake Time
    Last Post: 03-15-2005, 01:33 PM
  3. Avid Juicy 7 n00b questions.
    By martynda in forum Brake Time
    Last Post: 09-22-2004, 07:52 AM
  4. Avid Juicy 7 203mm disc availability ?
    By JerryBoneJr in forum Brake Time
    Last Post: 05-06-2004, 10:41 AM
