Results 1 to 5 of 5
    Avid juicy 7 caliper kit
    Does anyone have a source for juicy 7 caliper repair kit with the pistons? I've order the bleed kit and I need to repair caliper. Piston is sticking badly after I washed it too vigorously. I tryed the unstickining tricks but no luck.
    Thanks for any help.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Any LBS can order it from their distributors.
    They don't offer a minor caliper rebuild kit that I'm aware of. They only offer an entire caliper rebuild that costs $35. Jenson has one.
    I fixed mine just by disassembling it per the Avid directions and washing everything in alcohol very good. I then used 1000 grit sandpaper to fix the inboard piston that was sticking. All is good so far.
    Quote Originally Posted by HPHN
    Did you have Jenson rebuild your caliper or did you order a rebuilt one via Jenson website?
    Quote Originally Posted by dapcham
    He is referring to a rebuild KIT available at Jenson.
